Problem while launching envi in gazebo
I get an error while trying to run the following command roslaunch mybot_gazebo büro.launch
    <?xml version="1.0"?>
<launch>
<!-- We resume the logic in empty_world.launch, changing only the name of the world to be launched -->
    <arg name="world_name" value="$(find mybot_gazebo)/src/worlds/world_1.world"/>
    <!-- more default parameters can be changed here -->
<param name="robot_description" command="xacro --inorder '$(find mybot_descriptions)/src/urdf/turtlebot3_nano_urdf.xacro'" />
<!-- Spawn a robot into Gazebo -->
<node name="spawn_urdf" pkg="gazebo_ros" type="spawn_model" args="-param robot_description -urdf -model turtlebot3_nano" />
</launch>
This is what I get in the terminal window:
fsd@ubuntu:~$ roslaunch mybot_gazebo büro.launch
... logging to /home/fsd/.ros/log/fa739096-5358-11ea-83e5-000c29ac3d84/roslaunch-ubuntu-27683.log
Press Ctrl-C to interrupt
started roslaunch server http://localhost:43567/
SUMMARY
PARAMETERS
 * /robot_description: <?xml version="1....
 * /rosdistro: kinetic
 * /rosversion: 1.12.14
 * /use_sim_time: True
NODES
    gazebo (gazebo_ros/gzserver)
    gazebo_gui (gazebo_ros/gzclient)
    spawn_urdf (gazebo_ros/spawn_model)
process[gazebo-1]: started with pid [27704]
process[gazebo_gui-2]: started with pid [27709]
process[spawn_urdf-3]: started with pid [27714]
[ INFO] [1582145234.633496392]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1582145234.640886000]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1582145234.660926474]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1582145234.662592343]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1582145234.933423577, 162.147000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1582145234.974994371, 162.179000000]: Physics dynamic reconfigure ready.
[spawn_urdf-3] process has finished cleanly
log file: /home/fsd/.ros/log/fa739096-5358-11ea-83e5-000c29ac3d84/spawn_urdf-3*.log
[ INFO] [1582145235.582623332, 162.271000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1582145235.629225497, 162.317000000]: Physics dynamic reconfigure ready.
gzserver: /build/ogre-1.9-mqY1wq/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreRenderSystem.cpp:546: virtual void Ogre::RenderSystem::setDepthBufferFor(Ogre::RenderTarget*): Assertion `bAttached && "A new DepthBuffer for a RenderTarget was created, but after creation" "it says it's incompatible with that RT"' failed.
Aborted (core dumped)
[gazebo-1] process has died [pid 27704, exit code 134, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver -e ode /home/fsd/turtlebot_ws/src/mybot_gazebo/src/worlds/world_1.world __name:=gazebo __log:=/home/fsd/.ros/log/fa739096-5358-11ea-83e5-000c29ac3d84/gazebo-1.log].
log file: /home/fsd/.ros/log/fa739096-5358-11ea-83e5-000c29ac3d84/gazebo-1*.log
any suggestions to solve this error. Thank you :)
Asked by dhaour9x on 2020-02-20 11:10:40 UTC
What is the output of glxinfo | grep 'server glx vendor' ?
Asked by Jose Luis Rivero on 2020-02-24 18:20:15 UTC
this is the outpu of :glxinfo | grep 'server glx vendor'
server glx vendor string: SGI
Asked by dhaour9x on 2020-02-27 09:52:19 UTC
I'm afraid that you are not running hardware acceleration and that is probably the reason of the fail.
Asked by Jose Luis Rivero on 2020-03-12 11:31:25 UTC
