Cannot spawn robot model correctly after adding gazebo_ros_control PID parameters in .yaml robot_control config file
Dear all,
I am facing the following situation:
I can spawn my 4-wheel robot correctly to Gazebo but while loading I get an error message:
No p gain specified for pid. Namespace: /gazebo_ros_control/pid_gains/BRJ
Searching for a solution I came up with various answers proposing to add:
# gazebo_ros_control_params.yaml
/gazebo_ros_control:
pid_gains:
FRJ:
p: 100.0
i: 1.0
d: 0.1
FLJ:
p: 100.0
i: 1.0
d: 0.1
BRJ:
p: 100.0
i: 1.0
d: 0.1
BLJ:
p: 100.0
i: 1.0
d: 0.1
in robot_control.yaml configuration file. When I do so, the error message disappears but then, my model is not spawned correctly in Gazebo. Specifically, the 4 wheels are missing and a small portion of my model is placed inside the ground.
Any ideas why this behavior?
robot_control.yaml:
robot:
# Publish all joint states -----------------------------------
joint_state_controller:
type: joint_state_controller/JointStateController
publish_rate: 50
# # Position Controllers ---------------------------------------
# FLJ_position_controller:
# type: effort_controllers/JointPositionController
# joint: FLJ
# pid: {p: 1.0, i: 1.0, d: 0.0}
# FRJ_position_controller:
# joint: FRJ
# BLJ_position_controller:
# joint: BLJ
# BRJ_position_controller:
# joint: BRJ
# Velocity Controllers ---------------------------------------
FRJ_velocity_controller:
type: velocity_controllers/JointVelocityController
joint: FRJ
#pid: {p: 100.0, i: 10.0, d: 0.0}
FLJ_velocity_controller:
joint: FLJ
BRJ_velocity_controller:
joint: BRJ
BLJ_velocity_controller:
joint: BLJ
gazebo_ros_control:
pid_gains:
FRJ:
p: 100.0
i: 1.0
d: 0.1
FLJ:
p: 100.0
i: 1.0
d: 0.1
BRJ:
p: 100.0
i: 1.0
d: 0.1
BLJ:
p: 100.0
i: 1.0
d: 0.1
URDF:
<?xml version="1.0" ?>
<!-- | This document was autogenerated by xacro from robot.xacro | -->
<!-- | EDITING THIS FILE BY HAND IS NOT RECOMMENDED | -->
<robot name="robot" xmlns:xacro="http://www.ros.org/wiki/xacro">
<!--This URDF was automatically created by SolidWorks to URDF Exporter! Originally created by Stephen Brawner (brawner@gmail.com)
Commit Version: 1.5.1-0-g916b5db Build Version: 1.5.7152.31018
For more information, please see http://wiki.ros.org/sw_urdf_exporter -->
<link name="dummy">
<link name="base_link">
<origin rpy="0 0 0" xyz="0.00390777224516517 -0.032446267219719 0.184169550820421"/>
<mass value="40.20121630268732"/>
<inertia ixx="0.0149000386129946" ixy="-4.66831001352174E-09" ixz="5.23920338795194E-08" iyy="0.0234359493013497" iyz="0.000771538751024883" izz="0.0286744535302635"/>
<visual>
<origin rpy="0 0 0" xyz="0 0 0"/>
<mesh filename="package://robot/meshes/base_link.STL"/>
<material name="">
<color rgba="0.529411764705882 0.549019607843137 0.549019607843137 1"/>
<collision>
<joint name="dummy_joint" type="fixed">
<parent link="dummy"/>
<child link="base_link"/>
<link name="FL">
<origin rpy="0 0 0" xyz="-5.55111512312578E-17 9.10729824887824E-18 -6.93889390390723E-18"/>
<mass value="0.0615219544751675"/>
<inertia ixx="5.54433425808419E-05" ixy="-1.45453466603006E-20" ixz="-1.00225538664655E-21" iyy="3.00921775305435E-05" iyz="2.309188417276E-21" izz="3.00921775305435E-05"/>
<visual>
<mesh filename="package://robot/meshes/FL.STL"/>
<material name="">
<color rgba="0.298039215686275 0.298039215686275 0.298039215686275 1"/>
<collision>
<surface>
<friction>
<ode>
<mu>1000.0</mu>
<mu2>1000.0</mu2>
</ode>
</friction>
<contact>
<ode>
<min_depth>0.00</min_depth>
</ode>
</contact>
</surface>
<joint name="FLJ" type="continuous">
<origin rpy="1.5707963267949 0 0" xyz="-0.162088045105054 0.0440194465480433 -0.0035605397876617"/>
<parent link="base_link"/>
<child link="FL"/>
<axis xyz="-1 0 0"/>
<link name="FR">
<origin rpy="0 0 0" xyz="2.77555756156289E-17 -5.3776427755281E-17 3.46944695195361E-17"/>
<inertia ixx="5.54433425808419E-05" ixy="-1.73616162087809E-20" ixz="-8.97406720914896E-21" iyy="3.00921775305435E-05" iyz="-2.24902265994014E-21" izz="3.00921775305435E-05"/>
<visual>
<mesh filename="package://robot/meshes/FR.STL"/>
<material name="">
<collision>
<surface>
<friction>
<ode>
<mu>1000.0</mu>
<mu2>1000.0</mu2>
</ode>
</friction>
<contact>
<ode>
</ode>
</contact>
</surface>
<joint name="FRJ" type="continuous">
<origin rpy="1.5707963267949 0 0" xyz="0.169947769597777 0.0440194465480434 -0.00356053978766185"/>
<child link="FR"/>
<link name="BL">
<origin rpy="0 0 0" xyz="-5.55111512312578E-17 7.85396053748499E-16 -1.38777878078145E-17"/>
<inertia ixx="5.54433425808419E-05" ixy="-5.54431358512462E-21" ixz="2.27097066282367E-22" iyy="3.00921775305435E-05" iyz="2.73146067339844E-21" izz="3.00921775305435E-05"/>
<visual>
<mesh filename="package://robot/meshes/BL.STL"/>
<material name="">
<collision>
<surface>
<friction>
<ode>
<mu>1000.0</mu>
<mu2>1000.0</mu2>
</ode>
</friction>
<contact>
<ode>
</ode>
</contact>
</surface>
<joint name="BLJ" type="continuous">
<origin rpy="1.5707963267949 0 0" xyz="-0.162088045105054 -0.0759805534519569 -0.00356053978766179"/>
<child link="BL"/>
<link name="BR">
<origin rpy="0 0 0" xyz="-8.32667268468867E-17 7.03430369508595E-16 2.77555756156289E-17"/>
<inertia ixx="5.54433425808419E-05" ixy="-7.26178700863739E-21" ixz="-6.24920580783796E-21" iyy="3.00921775305435E-05" iyz="-3.51228039755728E-21" izz="3.00921775305435E-05"/>
<visual>
<mesh filename="package://robot/meshes/BR.STL"/>
<material name="">
<collision>
<surface>
<friction>
<ode>
<mu>1000.0</mu>
<mu2>1000.0</mu2>
</ode>
</friction>
<contact>
<ode>
</ode>
</contact>
</surface>
<joint name="BRJ" type="continuous">
<origin rpy="1.5708 0 0" xyz="0.16991 -0.075981 -0.0035605"/>
<child link="BR"/>
<link name="TB">
<origin rpy="0 0 0" xyz="-7.8063E-18 1.3878E-17 0.001"/>
<mass value="0.36807"/>
<inertia ixx="0.00019523" ixy="7.0972E-20" ixz="-4.0656E-22" iyy="0.0026688" iyz="4.5169E-23" izz="0.0028638"/>
<visual>
<mesh filename="package://robot/meshes/TB.STL"/>
<material name="">
<color rgba="0.52941 0.54902 0.54902 1"/>
<collision>
<joint name="TBJ" type="fixed">
<origin rpy="0 0 0" xyz="0.003912 -0.086602 0.46844"/>
<child link="TB"/>
<axis xyz="0 0 0"/>
<!-- LIDAR -->
<gazebo reference="hokuyo_link">
<sensor name="head_hokuyo_sensor" type="ray">
<pose> 0 0 0 0 0 0 </pose>
<update_rate>40</update_rate>
<ray>
<scan>
<horizontal>
<samples>720</samples>
<resolution>1</resolution>
<min_angle>-1.57079</min_angle>
<max_angle>1.57079</max_angle>
</horizontal>
</scan>
<range>
<min>0.1</min>
<max>30</max>
<resolution>0.1</resolution>
</range>
</ray>
<plugin filename="libgazebo_ros_laser.so" name="gazebo_ros_head_hokuyo_controller">
<topicName>/scan</topicName>
<frameName>hokuyo_link</frameName>
<joint name="TB_Lidar" type="fixed">
<axis xyz="0 1 0"/>
<parent link="TB"/>
<child link="hokuyo_link"/>
<origin rpy="0 0 1.57079633" xyz="0 0 0.005"/>
<!-- Hokuyo Laser -->
<link name="hokuyo_link">
<collision>
<box size="0.01 0.01 0.01"/>
<!-- Gazebo Ros Control Plugin -->
<gazebo>
<plugin filename="libgazebo_ros_control.so" name="gazebo_ros_control">
<robotNamespace>/robot</robotNamespace>
<legacyModeNS>true</legacyModeNS>
<!-- Gazebo Transmission -->
<transmission name="FLT">
<actuator name="motor1">
</actuator>
<joint name="FLJ">
</transmission>
<transmission name="FRT">
<actuator name="motor2">
</actuator>
<joint name="FRJ">
</transmission>
<transmission name="BLT">
<actuator name="motor3">
</actuator>
<joint name="BLJ">
</transmission>
<transmission name="BRT">
<actuator name="motor4">
</actuator>
<joint name="BRJ">
</transmission>
<!-- Differential Drive
<gazebo>
<plugin name="differential_drive_controller" filename = "libgazebo_ros_diff_drive.so">
<leftJoint>FLJ</leftJoint>
<legacyMode>false</legacyMode>
<rightJoint>FRJ</rightJoint>
<wheelSeperation>0.25</wheelSeperation>
<wheelDiameter>0.07</wheelDiameter>
<publishWheelJointState>true</publishWheelJointState>
</robot>
My configuration is: ROS Kinetic, Gazebo-7
Asked by Michael1973 on 2020-03-04 18:03:58 UTC
