CMake Gazebo warnings with ROS
When I build my package in ROS, I get the following list of warnings:
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_client.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_gui.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_sensors.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_rendering.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_physics.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_ode.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_transport.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_msgs.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_util.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_common.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_gimpact.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_opcode.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_opende_ou.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_math.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libgazebo_ccd.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_thread.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_signals.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_system.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_filesystem.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_program_options.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_regex.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_iostreams.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_date_time.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_chrono.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libboost_atomic.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libpthread.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libprotobuf.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libsdformat.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libignition-math2.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libOgreMain.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libOgreTerrain.so: not a directory
cc1plus: warning: /usr/lib/x86_64-linux-gnu/libOgrePaging.so: not a directory
My CMake file looks like this:
cmake_minimum_required(VERSION 2.8.3)
project(nena_simulation)
## Compile as C++11, supported in ROS Kinetic and newer
add_compile_options(-std=c++11)
find_package(catkin REQUIRED COMPONENTS
gazebo_ros
roscpp
rospy
controller_manager
joint_state_controller
robot_state_publisher
geometry_msgs
message_generation
find_package(gazebo REQUIRED)
link_directories(${GAZEBO_LIBRARY_DIRS})
include_directories(${Boost_INCLUDE_DIR} ${catkin_INCLUDE_DIRS} ${GAZEBO_INCLUDE_DIRS})
## Declare ROS messages, services and actions ##
## Generate messages in the 'msg' folder
add_message_files(
FILES
CustomModelState.msg
CustomPose.msg
generate_messages(
DEPENDENCIES
geometry_msgs
## Declare ROS dynamic reconfigure parameters ##
catkin_package(
INCLUDE_DIRS include
LIBRARIES gazeboPOSE
CATKIN_DEPENDS roscpp rospy message_runtime
## catkin specific configuration ##
## Build ##
include
${GAZEBO_LIBRARIES}
add_library(gazebo_optitrack src/gazeboPOSE.cpp)
add_dependencies(gazebo_optitrack ${nena_simulation_EXPORTED_TARGETS})
target_link_libraries(gazebo_optitrack ${catkin_LIBRARIES} ${GAZEBO_LIBRARIES})
add_executable(spawn_boxes_node src/spawn_boxes.cpp)
target_link_libraries(spawn_boxes_node ${catkin_LIBRARIES} ${GAZEBO_LIBRARIES})
## Install ##
## Testing ##
I'm not sure where these warnings are coming from and would like to resolve them, if possible. If anybody would know how, that would be much appreciated
Asked by joe28965 on 2020-03-09 04:02:55 UTC
