gazebo publishing oscillating effort values for for a prismatic joint
I'm having a robot urdf having a lifting mehanism with a prismatic joint with the base link. I have setup controller of type: effort_controllers/JointPositionController
at this joint.
the joint is:<joint name="lift_unit_joint" type="prismatic">
<parent link="base_link"/>
<child link="lift_unit_base"/>
<limit effort="2000" lower="-0.07" upper="0.00" velocity="0.02"/>
<origin rpy="0 ${M_PI/2} 0" xyz="0 0 0"/>
<!--<safety_controller k_velocity="10000" k_position="10000" soft_lower_limit="-0.06" soft_upper_limit="0.03" /> -->
After adjusting the pid values I'm able to reach the setpoint. The lift controller gives the command values which looks ok. but the joint_state is oscillating to 0.
This happens when there lifting unit has a load on top of it.
Note: I'm not using joint_state_publisher
as it initially gave zero values in between for positions of the lifting unit joint.
Asked by ajal on 2020-03-11 11:30:59 UTC
