Cannot open local sdf file in ignition gazebo
asked 2020-03-15 09:05:46 -0500
Jaeyoung-Lim gravatar image
updated 2020-03-19 03:31:55 -0500
Continuing Discussion from: https://community.gazebosim.org/t/can...
I am trying out the ignition gazebo citadel, and I am a bit confused on how this works compared to the classical gazebo.
I have a local model.sdf that I want to open in ignition gazebo. However, the application exists without any obvious errors. The output on the console is as the following.
ign gazebo ./model.sdf -v 5
[Msg] Ignition Gazebo Server v2.15.0
[Msg] Ignition Gazebo GUI    v2.15.0
[Msg] Loading SDF world file[/home/jaeyoung/src/Firmware/Tools/sitl_gazebo/models/uneven_ground/./model.sdf].
[Dbg] [Application.cc:87] Initializing application.
[GUI] [Dbg] [Application.cc:407] Create main window
[Dbg] [ign.cc:150] Shutting down ign-gazebo-server
[GUI] [Dbg] [SignalHandler.cc:141] Received signal[2].
[GUI] [Dbg] [Application.cc:130] Terminating application.
Version of ignition gazebo is:
$ ign gazebo --version
Ignition Gazebo, version 2.15.0
Copyright (C) 2018 Open Source Robotics Foundation.
Released under the Apache 2.0 License.
Update: The sdf file I am trying to spawn is this one: https://github.com/PX4/sitl_gazebo/bl...
But also other models in the repo have the same result
Update
@chapulina Thanks for the answer,
I created a sdf file following your suggestion, as the following
<?xml version="1.0" ?>
<sdf version="1.6">
    <!-- Runs physics -->
    filename="libignition-gazebo-physics-system.so"
    name="ignition::gazebo::systems::Physics">
    <!-- Broadcasts the server state to the GUI -->
    filename="libignition-gazebo-scene-broadcaster-system.so"
    name="ignition::gazebo::systems::SceneBroadcaster">
    <!-- Supports commands like spawning and teleporting entities -->
    filename="libignition-gazebo-user-commands-system.so"
    name="ignition::gazebo::systems::UserCommands">
however it still fails to load anything
$ ign gazebo ./ignition.world -v 5
[Msg] Loading SDF world file[/home/jaeyoung/src/Firmware/Tools/sitl_gazebo/worlds/./ignition.world].
[GUI] [Dbg] [ign.cc:230] GUI requesting list of world names. The server may be busy downloading resources. Please be patient.
Update2
@chapulina Although adding the default world plugins stopped the ign client from crashing, I still cannot spawn models such as https://github.com/PX4/sitl_gazebo/tr... into the world. And does the model always need to be predefined inside the world sdf file? Is it possible to spawn vehicles in a already existing world?
I moved the other answer you created to an update to the question. You will need to add the <plugin> tags to the SDF world file you're loading, inside the <world> tag.
chapulina gravatar imagechapulina ( 2020-03-17 11:36:41 -0500 )edit
Thanks! That worked.
Jaeyoung-Lim gravatar imageJaeyoung-Lim ( 2020-03-18 04:16:28 -0500 )edit
answered 2020-03-15 11:22:10 -0500
While on Gazebo-classic all features are enabled at all times, even if users don't need them, on Ignition users can turn on only the features they need.
Right now, all necessary features must be explicitly enabled on the SDF file. We're already working on a way for Ignition to load a few default plugins if the user doesn't specify any, but this will only be available in the upcoming minor releases.
Until then, you should include all world plugins that you need, like Physics and SceneBroadcaster. Here's a good list to start with:
Asked: 2020-03-15 09:05:46 -0500
Seen: 83 times
Last updated: Mar 19
