Gazebo 11 installation problems
Hello to everyone I am trying to install Gazebo 11 in my computer running the downloaded script but i get the following error:
The following packages have unmet dependencies: gazebo11 : Depends: libgazebo11 (= 11.0.0-1~bionic) but it is not going to be installed Recommends: gazebo11-plugin-base libgazebo11-dev : Depends: libgazebo11 (= 11.0.0-1~bionic) but it is not going to be installed Depends: gazebo11-plugin-base (= 11.0.0-1~bionic) E: Unable to correct problems, you have held broken packagessudo
I am running kubuntu 18.03 and have also installed the Robot Operating System (ROS) that using Gazebo 9.
Any suggestions or ideas? Thanks in advance
Asked by berny on 2020-03-17 14:56:27 UTC
I have the same problem. Weirdly enough if you try to install directly libgazebo11 there should be no problem to install it:
sudo apt install libgazebo11
After that you can rerun the installation script and it runs perfectly. But this is not an acceptable solution for me as I am on Docker so having a script that fail is definitely a problem. Can someone provide a solution for the script?
EDIT: I think I figured out what is the problem. I tried to follow the manual installation in http://gazebosim.org/tutorials?tut=install_ubuntu&cat=install#Alternativeinstallation:step-by-step
I run into the exact same problem when doing sudo apt-get install gazebo11. I believe the script should also install libgazebo11 and it does not. If you include that then it works. Can someone modify the script to include the installation of libgazebo11?
Asked by buschbapti on 2020-03-30 03:03:23 UTC
