Relatively small parts do not convert well to gazebo
Hello  I am converting my robot arm to gazebo. solidworks 2018 / ROS: kinetic , gazebo: 7.0
★Problem 1. Relatively small parts do not convert well to gazebo
Especially Gripper Links >> gazebo: Play >> Collapse
#Test: 1. Gripper Link: Mass Increase >> collapse 2. Dipper(3) & Wrist(4): Vibration occurs >> combine >> Command: OK
#Code: open_manipulator See ... Under test: Complex / Coming soon
openmanipulatordescription https://github.com/ROBOTIS-GIT/open_manipulator
openmanipulatorgazebo https://github.com/ROBOTIS-GIT/open_manipulator_simulations
#Working process: One Step Assembly
1th: Coordinate system: Based on Front / Male
2th: Axis : Female
image description image description
3th: Boom(2): Link_2 >> command: OK image description
4th: Dipper(3): Vibration occurs / command: OK -------> small Size Wrist(4) : More vibration image description
5th: Dipper Combine(3+4) / Wrist(4): Remove >> ★Not vibration / command: OK image description
6th: Link5: Vibration occurs / command: OK image description
7th: GripperServoGear -----------> Very small Size(Relatively) >> collapse image description image description image description image description Thank you.
Asked by ikim on 2020-03-18 01:47:05 UTC
Have you managed to make it work? I am facing the same issue, related to small links in a gripper.
Asked by yiying on 2020-03-26 15:50:17 UTC
