Fixed joint unstable compared to revolute joint
I'm building a robot. Some of the joints are "fixed" However I notive that these fixed joint are really unstable. Replacing it with revolute joint with 0 limit works better.
This happens when the ratio between two links is very high: in the following example the cube is 3000kg while the cylinder is only 0.1kg. This is done to illustrate.
Here is a GIF of what happens when trying to apply forces on the cylinder link (on the left the fixed joint vs the revolute joint on the right)
C:\fakepath\Peek 2020-03-20 16-09.gif
Note: this is easily reproducible by running gazebo and creating the model directly from the model editor.
Asked by ejalaa12 on 2020-03-20 10:12:00 UTC
