Robot links implode to origin
I'm using ubuntu 16.04 on a Huawei Matebook-x, with kernel 4.15.0-91-generic. ROS distro: kinetic and version 1.12.14. Gazebo 7.
My package for the robot is at https://github.com/yiyinglai/FetchIt_....
I have seen answers and videos about similar problem, and I did what's suggested for the inertia calculation for niryo_gripper.urdf.xacro using the following script.
def inertia(m, x, y, z):
    """Solid cuboid of height h, width w, and length l, and mass m."""
    Ixx = m * (y**2 + z**2) / 12
    Iyy = m * (x**2 + z**2) / 12
    Izz = m * (x**2 + y**2) / 12
    tag = '<inertia ixx="{}" ixy="0.0" ixz="0.0" iyy="{}" iyz="0.0" izz="{}"/>'.format(Ixx, Iyy, Izz)
    return tag
if __name__ == '__main__':
    # mainsupport mass bounding box x, y, z
    print('mainsupport')
    print(inertia(0.01306, 0.0446, 0.0511, 0.044))
    print('left gear')
    print(inertia(0.0043, 0.022038, 0.049874, 0.01155))
    print('right gear')
    print(inertia(0.00375, 0.02207, 0.049804, 0.008))
    print('rod')
    print(inertia(0.00214, 0.012501, 0.041893, 0.016))
    print('clamp')
    print(inertia(0.00662, 0.027452, 0.06758, 0.016))
    print('motor')
    print(inertia(0.01658, 0.036, 0.024, 0.027))
When I launch gazebo simulation, I get a quite normal output on console:
... logging to /home/yiying/.ros/log/881f6094-6f12-11ea-b6cd-7c11cb4ab0c1/roslaunch-matebook-x-3897.log
Press Ctrl-C to interrupt
started roslaunch server http://matebook-x:44093/
SUMMARY
PARAMETERS
 * /robot_description: <?xml version="1....
 * /rosdistro: kinetic
 * /rosversion: 1.12.14
 * /use_sim_time: True
NODES
    gazebo (gazebo_ros/gzserver)
    gazebo_gui (gazebo_ros/gzclient)
    spawn_urdf (gazebo_ros/spawn_model)
auto-starting new master
process[master]: started with pid [3922]
setting /run_id to 881f6094-6f12-11ea-b6cd-7c11cb4ab0c1
process[rosout-1]: started with pid [3935]
process[gazebo-2]: started with pid [3939]
process[gazebo_gui-3]: started with pid [3964]
process[spawn_urdf-4]: started with pid [4005]
Gazebo multi-robot simulator, version 7.0.0
Copyright (C) 2012-2016 Open Source Robotics Foundation.
http://gazebosim.org
[ INFO] [1585193598.698783796]: Finished loading Gazebo ROS API Plugin.
[Msg] Waiting for master.
[ INFO] [1585193598.700128591]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[Msg] Publicized address: 192.168.2.31
[ INFO] [1585193598.751193527]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1585193598.751826873]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
SpawnModel script started
[INFO] [1585193598.978037, 0.000000]: Loading model XML from ros parameter
[INFO] [1585193598.981118, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[ INFO] [1585193599.212867836, 0.022000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1585193599.250930627, 0.060000000]: Physics dynamic reconfigure ready.
[INFO] [1585193599.286868, 0.090000]: Calling service /gazebo/spawn_urdf_model
[INFO] [1585193599.446658, 0.147000]: Spawn status: SpawnModel: Successfully spawned entity
[ INFO] [1585193599.594736722, 0.147000000]: Loading gazebo_ros_control plugin
[ERROR] [1585193599.594865205, 0.147000000]: GazeboRosControlPlugin missing <legacyModeNS> while using DefaultRobotHWSim, defaults to true.
This setting assumes you have an old package with an old implementation of DefaultRobotHWSim, where the robotNamespace is disregarded and absolute paths are used instead.
If you do not want to fix this issue in an old package just set <legacyModeNS> to true.
[ INFO] [1585193599.594952933, 0.147000000]: Starting gazebo_ros_control plugin in namespace: /
[ INFO] [1585193599.596227126, 0.147000000]: gazebo_ros_control plugin is waiting for model URDF in parameter [robot_description] on the ROS param server.
[spawn_urdf-4] process has finished cleanly
log file: /home/yiying/.ros/log/881f6094-6f12-11ea-b6cd-7c11cb4ab0c1/spawn_urdf-4*.log
[ INFO] [1585193599.718851948, 0.147000000]: Loaded gazebo_ros_control.
[ INFO] [1585193599.741055324, 0.170000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1585193599.790204603, 0.217000000]: Physics dynamic reconfigure ready.
In gazebo, except for the mainsupport link, all the links collapse into the origin as shown in the figure below: initial
As soon as I go to editor, console outputs the following:
Error [Param.hh:265] Unable to set parameter[velocity].Type type used must have a stream input and outputoperator, which allow boost::lexical_cast tofunction properly.
Error [Param.hh:265] Unable to set parameter[acceleration].Type type used must have a stream input and outputoperator, which allow boost::lexical_cast tofunction properly.
Error [Param.hh:265] Unable to set parameter[wrench].Type type used must have a stream input and outputoperator, which allow boost::lexical_cast tofunction properly.
[Err] [JointMaker.cc:1465] Unable to load joint. Joint child / parent not found
and the model in editor looks normal, as shown below: editor
Links are at the correct positon. And if I exit editor without doing anything and reset gazebo simulation (in either sequence) using
rosservice call /gazebo/reset_simulation
, the robot appears correctly as shown below: after
Inspecting the inertia, it seems pretty normal. inertia
Thank you in advance for helping me out!
Edit #1: I misunderstood what reset_simulation does and found out if I unpause physics, the links implode just like in the first screenshot.
Edit #2: I made all inertia values of the links three time magnitude larger than the original ones. It's not ideal, but the implosion does not occure now. The gripper package will be deleted and it will appear in the niryo_one package. Question closed.
Asked by yiying on 2020-03-26 12:34:35 UTC
