Gserver segmentation fauilt
Hi, I'm trying to simulate a Rethink Sawyer Robot in gazebo with ros integration inside a docker container. I'm running Ros Melodic and gazebo 9.0. I've downloaded the official moveit and gazebo bindings from rethink's github. When I try the example simulation:
roslaunch sawyer_gazebo sawyer_world.launch debug:=true
I see that gzserver
segfaults. Here is the log with the crash happening near the end:
Here is the launch file that it is using.
One other odd thing I've noticed, sometimes gazebo starts successfully, but the model it loads up is missing a joint:
On a final note: gdb for some reason can't attach to the process. I see that the debug
flag is used in the gazebo_ros
package to run the debug
script. This doesn't allow me to attach the debugger the normal way (eg: `launch-prefix="xterm -e gdb ... "). Any work arounds for this?
Asked by rrklutz on 2020-03-26 17:10:55 UTC
