Wheel-terrain interaction with Gazebo
Up to now, I haven't found any evidence that Gazebo physics engine provides an accurate simulation of the wheel-terrain interaction between rigid wheels and soft soils. According to the ODE documentation, only the contact between rigid wheels and rigid soils is simulated through the Coulomb Friction Model.
I would like know if any of you has some knowledge on how to simulate the contact between rigid wheels and soft, deformable soils in Gazebo.
Thanks in advance !
Asked by Francisco Castro on 2020-03-26 19:48:11 UTC
I am not sure if that is possible. If it is, I am fairly certain that is going to run really slow, but if you don't need to run it in real time then ProjectChrono may have what you are looking for.
Asked by rittersb on 2020-04-03 18:03:50 UTC
I am currently working on a terrain model to simulate rigid wheels in soft deformable terrain as part of my thesis. It currently exists as a ROS node that subscribes to the link states and joint states from Gazebo, then calls Gazebo services to apply the relevant forces and torques. I'd be happy to share what I have so far with you if you provided an email address
Asked by Joshua658413 on 2020-10-12 09:13:30 UTC
Hello! I would be happy get in touch with you. My nearest bet so far is an interface I found with Gazebo and Project Chrono, but as I need a real-time solution I don't know if it will work. Here's my email: francisco.de.castro@ist.utl.pt
Asked by Francisco Castro on 2020-12-24 22:01:58 UTC
I'm also working to simulate wheel-soil interaction in Gazebo. I've came to this thread and wondered if there was any updates. Also, I was wondering if the source code was on github or somewhere else. I would be looking forward for your reply.
Asked by Go Sakayori on 2021-09-15 23:25:33 UTC
Hi Joshua, I am started working on wheel-terrain interaction of soft/loose soil. I will like to start my simulation in gazebo, but doesn't have any help. Please I will also like to share with me your model.
My emal: ahmadbukar90@gmail.com
Regards Ahmad
Asked by Ahmad Abubakar on 2021-11-10 16:56:53 UTC
Hello, could you also share the code with me ? my email id is - a.pagariya@nisar.ai.
Just a side note: 1. I am also checking if I can get ROS and Chrono together.
Thanks in advance!
Asked by pagariya on 2023-01-25 07:33:20 UTC
Hello Joshua, I work with Chrono in the las half year, but I was not able to speed up the simulation to get the necessary performance. I am a little bit disappointed. I would be happy to try your implementation as we are planning to use Humble for later on. mail: doba.daniel.karoly@kjk.bme.hu Thank you.
Asked by DanielDoba on 2023-06-18 16:41:45 UTC
