[ignition] Blank window when trying to run shapes.sdf
when I try to run this command ign gazebo shapes.sdf -v 4
I got a blank window. I tried to run a world which uses Ogre1 ign gazebo -v 3 lights.sdf
but the same blank window. I also tried to use the Acropolis but the same issue
this is the output from the terminal when running lights.sdf
[Msg] Ignition Gazebo GUI v2.16.0
[Msg] Ignition Gazebo Server v2.16.0
[Msg] Loading SDF world file[/usr/share/ignition/ignition-gazebo2/worlds/lights.sdf].
[Msg] Create service on [/world/lights/create]
[Msg] Remove service on [/world/lights/remove]
[Msg] Pose service on [/world/lights/set_pose]
[Msg] Loaded level [3]
[Msg] Serving world controls on [/world/lights/control] and [/world/lights/playback/control]
[Msg] Serving GUI information on [/world/lights/gui/info]
[Msg] World [lights] initialized with [1ms] physics profile.
[Msg] Found no publishers on /stats, adding root stats topic
[Msg] Found no publishers on /clock, adding root clock topic
[Msg] Serving scene information on [/world/lights/scene/info]
[Msg] Serving graph information on [/world/lights/scene/graph]
[Msg] Serving full state on [/world/lights/state]
[Msg] Publishing scene information on [/world/lights/scene/info]
[Msg] Publishing entity deletions on [/world/lights/scene/deletion]
[Msg] Publishing state changes on [/world/lights/state]
[Msg] Publishing pose messages on [/world/lights/pose/info]
[Msg] Publishing dynamic pose messages on [/world/lights/dynamic_pose/info]
when running the shapes.sdf I got similar output adding the same output except this line is added
[GUI] [Dbg] [ign.cc:359] GUI requesting list of world names. The server may be busy downloading resources. Please be patient.
OS: Ubuntu 18.04
Ignition: Blueprint
OpenGL version string: 4.6.0 NVIDIA 390.116
Asked by Mohamed_Ahmed on 2020-03-28 01:35:30 UTC
Did you try to remove ~/.ignition/gazebo/gui.config
Asked by ahcorde on 2020-12-18 14:25:58 UTC
Are any errors / warnings printed which could indicate what's happening?
Asked by chapulina on 2020-03-28 11:27:43 UTC
I edited my question
Asked by Mohamed_Ahmed on 2020-03-28 11:58:17 UTC
While the window is black, could you check
ign service -l
to see if there's a/gazebo/worlds
service? You may need to run the command more than once.Asked by chapulina on 2020-03-30 11:37:36 UTC
I run the command multiple times but there is no output
Asked by Mohamed_Ahmed on 2020-03-31 01:10:47 UTC
Can you run
ign service --versions
and see if you have more than one installed? You may have a weird mix of versions and the client is not being able to speak to the server.Asked by chapulina on 2020-03-31 11:41:00 UTC
here is the output 7.4.0
6.0.0
4.0.0
Asked by Mohamed_Ahmed on 2020-04-01 02:36:37 UTC
Thanks, I see you have Gazebo 9, Ignition Acropolis and Ignition Blueprint installed. It looks like you're having this unresolved issue: https://bitbucket.org/ignitionrobotics/ign-gazebo/issues/38/gazebo-hangs-at-requesting-list-of-world
Asked by chapulina on 2020-04-01 11:55:07 UTC
@chapulina, is there a new link to that unresolved issue? The link appears broken.
Asked by SamG on 2022-07-05 20:39:34 UTC
