My model cannot run when i apply a force to the front wheels
Hi; I'm a gazebo novice user, i try to run my first example without success. can any body tell me why my car cannot run away when i set a forces to the front wheels please?
herein my model
model.sdf
<?xml version='1.0'?>
      <sdf version='1.4'>
     <model name='car'>
      <static>false</static>
      <link name='chassis'>
          <pose>0 0 0.8 0 0 0</pose>
          <collision name='collision'>
                      <size>4 2 1</size>
              <surface>
                  <friction>
                      <ode>
                          <mu>0</mu>
                          <mu2>0</mu2>
                          <fdir1>0 0 0</fdir1>
                          <slip1>0</slip1>
                          <slip2>0</slip2>
                      </ode>
                  </friction>
              </surface>
          <visual name='visual'>
                      <size>4 2 1</size>
                  <lighting>1</lighting>
                  <script>
                      <name>Gazebo/Grey</name>
                  </script>
                  <shader type='vertex'>
                      <normal_map>__default__</normal_map>
                  </shader>
                  <ambient>0.3 0.3 0.3 1</ambient>
                  <diffuse>0.7 0.7 0.7 1</diffuse>
                  <specular>0.01 0.01 0.01 1</specular>
                  <emissive>0 255 255 1</emissive>
          <collision name='collision_top'>
                      <size>1 2 0.6</size>
              <surface>
                  <friction>
                      <ode>
                          <mu>0</mu>
                          <mu2>0</mu2>
                          <slip1>0</slip1>
                          <slip2>0</slip2>
                      </ode>
                  </friction>
              </surface>
          <visual name='visual_top'>
                  <script>
                  </script>
                  </shader>
                  <emissive>255 0 255 1</emissive>
      <link name='wheel_front_left'>
          <pose>1.5 1.3 0.6 0 1.5707 1.5707</pose>
                  <cylinder>
                      <radius>0.6</radius>
                      <length>0.3</length>
                  </cylinder>
              <surface>
                  <friction>
                      <ode>
                          <mu>0</mu>
                          <mu2>0</mu2>
                          <slip1>0</slip1>
                          <slip2>0</slip2>
                      </ode>
                  </friction>
              </surface>
                  <cylinder>
                  </cylinder>
                  <script>
                  </script>
                  </shader>
                  <emissive>0 0 0 1</emissive>
      <link name='wheel_back_left'>
          <pose frame=''>-1.5 1.3 0.6 0 1.5707 1.5707</pose>
                  <cylinder>
                  </cylinder>
              <surface>
                  <friction>
                      <ode>
                          <mu>0</mu>
                          <mu2>0</mu2>
                          <slip1>0</slip1>
                          <slip2>0</slip2>
                      </ode>
                  </friction>
              </surface>
                  <cylinder>
                  </cylinder>
                  <script>
                  </script>
                  </shader>
      <link name='wheel_front_right'>
          <pose frame=''>1.5 -1.3 0.6 0 1.5707 1.5707</pose>
                  <cylinder>
                  </cylinder>
              <surface>
                  <friction>
                      <ode>
                          <mu>0</mu>
                          <mu2>0</mu2>
                          <slip1>0</slip1>
                          <slip2>0</slip2>
                      </ode>
                  </friction>
              </surface>
                  <cylinder>
                  </cylinder>
                  <script>
                  </script>
                  </shader>
      <link name='wheel_back_right'>
          <pose frame=''>-1.5 -1.3 0.6 0 1.5707 1.5707</pose>
                  <cylinder>
                  </cylinder>
              <surface>
                  <friction>
                      <ode>
                          <mu>0</mu>
                          <mu2>0</mu2>
                          <slip1>0</slip1>
                          <slip2>0</slip2>
                      </ode>
                  </friction>
              </surface>
                  <cylinder>
                  </cylinder>
                  <script>
                  </script>
                  </shader>
    <joint name='joint_front_left' type='revolute'>
        <parent>chassis</parent>
        <child>wheel_front_left</child>
        <pose>0 0 -0.3 0 0 0</pose>
        <axis>
            <xyz>0 1 0</xyz>
        </axis>
    <joint name='joint_back_left' type='revolute'>
        <child>wheel_back_left</child>
        <axis>
            <xyz>0 1 0</xyz>
        </axis>
    <joint name='joint_front_right' type='revolute'>
        <child>wheel_front_right</child>
        <pose>0 0 0.3 0 0 0</pose>
        <axis>
            <xyz>0 1 0</xyz>
        </axis>
    <joint name='joint_back_right' type='revolute'>
        <child>wheel_back_right</child>
        <axis>
            <xyz>0 1 0</xyz>
        </axis>
    </joint>   </model> </sdf>
model.config
<?xml version="1.0" ?>
<model>
    <name>car</name>
    <version>1.0</version>
    <sdf version="1.4">model.sdf</sdf>
    <author>
        <name></name>
        <email></email>
    </author>
    <description></description>
Asked by den78 on 2020-03-31 07:52:24 UTC
