Model slips on ground and cannot acheive given velocity
Hi, Im trying to implement a program for multi robot obstacle avoidance. Right now I have a code which outputs a desired velocity. However, my robot is never able to achieve the given velocity. Also the bot continues moving even after I stop the program. I have attached the URDF model below for the robot (has omni wheels with 10 rollers).
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro"
xmlns:controller="http://playerstage.sourceforge.net/gazebo/xmlschema/#controller"
xmlns:interface="http://ros.org/wiki/xacro"
xmlns:sensor="http://playerstage.sourceforge.net/gazebo/xmlschema/#sensor" name="ballbot">
<link name="dummy">
<xacro:macro name="omni" params="x y z roll pit yaw pos">
<link name="wheel${pos}">
<collision>
<origin xyz="0 0 0" rpy="${roll} ${pit} ${yaw}"/>
<mesh filename="package://omni_bot/src/Wheel2_Double_ohneRaeder.stl" scale=".0021 .0021 .0021"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
<fdir1>1 0 0</fdir1>
</ode>
</friction>
</surface>
<visual>
<mass value = "2.5"/>
<inertia ixx="0.00108333333333" ixy="0" ixz="0" iyy="0.00108333333333" iyz="0" izz="0.002"/>
<!-- <gravity> 1 </gravity>
<selfCollide>0</selfCollide> -->
<link name="roller1${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 0 1.57079"/>
<mesh filename="package://omni_bot/src/Wheel2_wheel_rightOrient.stl" scale=".0021 .0021 .0021"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<mass value = "0.1"/>
<inertia ixx="0.00000847" ixy ="0" ixz="0" iyy="0.00000847" iyz="0.0" izz="0.00000847"/>
<joint name="1${pos}" type="continuous">
<parent link="wheel${pos}"/>
<child link="roller1${pos}"/>
<origin xyz="${0.222*(-(0)*sin(yaw)+((0.05-0.28)*sin(pit)+(0.137)*cos(pit))*cos(yaw))} ${0.222*(((0)*cos(yaw))+((0.05-0.28)*sin(pit)+(0.137)*cos(pit))*sin(yaw))} ${0.222*((0.05-0.28)*cos(pit)+0.28-(0.137)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 1 0"/>
<!-- <dynamics>
<damping>0.7</damping>
<friction>0.4</friction>
</dynamics> -->
<link name="roller2${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 -1.25664 1.57079"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<joint name="2${pos}" type="continuous">
<child link="roller2${pos}"/>
<origin xyz="${0.222*(-(0.21)*sin(yaw)+((0.208-0.28)*sin(pit)+(0.137)*cos(pit))*cos(yaw))} ${0.222*(((0.21)*cos(yaw))+((0.208-0.28)*sin(pit)+(0.137)*cos(pit))*sin(yaw))} ${0.222*((0.208-0.28)*cos(pit)+0.28-(0.137)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 0.31 0.95"/>
<!-- <dynamics>
</dynamics> -->
<link name="roller3${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 -2.5132 1.57079"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<joint name="3${pos}" type="continuous">
<child link="roller3${pos}"/>
<origin xyz="${0.222*(-(0.14)*sin(yaw)+((0.47-0.28)*sin(pit)+(0.137)*cos(pit))*cos(yaw))} ${0.222*(((0.14)*cos(yaw))+((0.47-0.28)*sin(pit)+(0.137)*cos(pit))*sin(yaw))} ${0.222*((0.47-0.28)*cos(pit)+0.28-(0.137)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 -0.81 0.59"/>
<!-- <dynamics>
</dynamics> -->
<link name="roller4${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 -3.7699 1.57079"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<joint name="4${pos}" type="continuous">
<child link="roller4${pos}"/>
<origin xyz="${0.222*(-(-0.14)*sin(yaw)+((0.47-0.28)*sin(pit)+(0.137)*cos(pit))*cos(yaw))} ${0.222*(((-0.14)*cos(yaw))+((0.47-0.28)*sin(pit)+(0.137)*cos(pit))*sin(yaw))} ${0.222*((0.47-0.28)*cos(pit)+0.28-(0.137)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 -0.81 -0.59"/>
<!-- <dynamics>
</dynamics> -->
<link name="roller5${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 1.25664 1.57079"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<joint name="5${pos}" type="continuous">
<child link="roller5${pos}"/>
<origin xyz="${0.222*(-(-0.22)*sin(yaw)+((0.21-0.28)*sin(pit)+(0.137)*cos(pit))*cos(yaw))} ${0.222*(((-0.22)*cos(yaw))+((0.21-0.28)*sin(pit)+(0.137)*cos(pit))*sin(yaw))} ${0.222*((0.21-0.28)*cos(pit)+0.28-(0.137)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 0.31 -0.95"/>
<!-- <dynamics>
</dynamics> -->
<link name="roller6${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 -0.6283 1.57079"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<joint name="6${pos}" type="continuous">
<child link="roller6${pos}"/>
<origin xyz="${0.222*(-(0.14)*sin(yaw)+((0.094-0.28)*sin(pit)+(0.01)*cos(pit))*cos(yaw))} ${0.222*(((0.14)*cos(yaw))+((0.094-0.28)*sin(pit)+(0.01)*cos(pit))*sin(yaw))} ${0.222*((0.094-0.28)*cos(pit)+0.28-(0.01)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 0.81 0.59"/>
<!-- <dynamics>
</dynamics> -->
<link name="roller7${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 -1.8849 1.57079"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<joint name="7${pos}" type="continuous">
<child link="roller7${pos}"/>
<origin xyz="${0.222*(-(0.22)*sin(yaw)+((0.35-0.28)*sin(pit)+(0.01)*cos(pit))*cos(yaw))} ${0.222*(((0.22)*cos(yaw))+((0.35-0.28)*sin(pit)+(0.01)*cos(pit))*sin(yaw))} ${0.222*((0.35-0.28)*cos(pit)+0.28-(0.01)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 -0.31 0.95"/>
<!-- <dynamics>
</dynamics> -->
<link name="roller8${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 -3.14159 1.57079"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<joint name="8${pos}" type="continuous">
<child link="roller8${pos}"/>
<origin xyz="${0.222*(-(0)*sin(yaw)+((0.51-0.28)*sin(pit)+(0.01)*cos(pit))*cos(yaw))} ${0.222*(((0)*cos(yaw))+((0.51-0.28)*sin(pit)+(0.01)*cos(pit))*sin(yaw))} ${0.222*((0.51-0.28)*cos(pit)+0.28-(0.01)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 -1 0"/>
<!-- <dynamics>
</dynamics> -->
<link name="roller9${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 -4.3982 1.57079"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<joint name="9${pos}" type="continuous">
<child link="roller9${pos}"/>
<origin xyz="${0.222*(-(-0.22)*sin(yaw)+((0.35-0.28)*sin(pit)+(0.01)*cos(pit))*cos(yaw))} ${0.222*(((-0.22)*cos(yaw))+((0.35-0.28)*sin(pit)+(0.01)*cos(pit))*sin(yaw))} ${0.222*((0.35-0.28)*cos(pit)+0.28-(0.01)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 -0.31 -0.95"/>
<!-- <dynamics>
</dynamics> -->
<link name="roller10${pos}">
<collision >
<origin xyz="0 0 0" rpy="0 -5.6548 1.57079"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual >
<joint name="10${pos}" type="continuous">
<child link="roller10${pos}"/>
<origin xyz="${0.222*(-(-0.14)*sin(yaw)+((0.094-0.28)*sin(pit)+(0.01)*cos(pit))*cos(yaw))} ${0.222*(((-0.14)*cos(yaw))+((0.094-0.28)*sin(pit)+(0.01)*cos(pit))*sin(yaw))} ${0.222*((0.094-0.28)*cos(pit)+0.28-(0.01)*sin(pit)-0.28)}" rpy="${roll} ${pit} ${yaw}"/>
<axis xyz="0 0.81 -0.59"/>
<gazebo>
<mu1 value="1.0"/>
<mu2 value="1.0"/>
<kp value="10000000.0"/>
<kd value="1.0"/>
<fdir1 value="1 0 0"/>
<turnGravityOff>false</turnGravityOff>
</xacro:macro>
<link name="body">
<collision>
<origin xyz="0 0 0.015625" rpy="0 0 0"/>
<mesh filename="package://omni_bot/src/body.stl" scale="0.001 0.001 0.001"/>
<surface>
<friction>
<ode>
<mu>0.6</mu>
<mu2>0.6</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
</surface>
<visual>
<origin xyz="0 0 0.065625"/>
<mass value = "5.0"/>
<inertia ixx="0.082916666667" ixy="0" ixz="0" iyy="0.082916666667" iyz="0" izz="0.1025"/>
<joint name="dummy_joint" type="fixed">
<parent link="dummy"/>
<child link="body"/>
<xacro:omni x="0.32" y="0.0" z="0.065625" roll="0" pit="0" yaw="0" pos="1">
</xacro:omni>
<xacro:omni x="-0.175" y="0.30310889" z="0.065625" roll="0" pit="0" yaw="-1.04719755" pos="2">
</xacro:omni>
<xacro:omni x="-0.16" y="-0.277128127" z="0.065625" roll="0" pit="0" yaw="-2.09439510" pos="3">
</xacro:omni>
<joint name="wheel_joint1" type="continuous">
<parent link="body" />
<child link="wheel1" />
<origin xyz="0.32 0.0 0.065625" rpy="0.0 0.0 0" />
<axis xyz ="1 0 0"/>
<limit effort="100" velocity="100"/>
<physics><ode><limit>
<cfm>0.000000</cfm>
<erp>0.900000</erp>
</limit></ode></physics>
<joint_properties damping="0.0" friction="0.0"/>
<transmission name="tran1">
<joint name="wheel_joint1">
<actuator name="motor1">
</actuator>
</transmission>
<joint name="wheel_joint2" type="continuous">
<child link="wheel2" />
<origin xyz="-0.175 0.30310889 0.065625" rpy="0.0 0.0 0" />
<axis xyz ="-0.5 0.866025 0"/>
<cfm>0.000000</cfm>
<erp>0.900000</erp>
<transmission name="tran2">
<joint name="wheel_joint2">
<actuator name="motor2">
</actuator>
</transmission>
<joint name="wheel_joint3" type="continuous">
<child link="wheel3" />
<origin xyz="-0.16 -0.277128127 0.065625" rpy="0.0 0.0 0" />
<axis xyz ="-0.5 -0.866025 0"/>
<cfm>0.000000</cfm>
<erp>0.900000</erp>
<transmission name="tran3">
<joint name="wheel_joint3">
<actuator name="motor3">
</actuator>
</transmission>
<gazebo>
</robot>
Radius of wheel shaft : 12.04 mm
Radius of wheel : 0.065625 m
Thickness of wheel : 0.0115 + 0.043 = 0.06 m
Length of roller : 18.41 mm
Radius of body : 0.25 m
Thickness of body : 10cm
Radius of Rod : 1.2 cm
Length of Rod 10 cm
C:\fakepath\Plot Name_page-0001.jpg
Also as seen in the plot the bot acheives only 0.6 as velocity when given a required velocity of 1
Asked by Withered_Shadow on 2020-04-07 00:33:52 UTC
