Where is element <gazebo> in the source code parsed?
Hi all,
I'm not sure if I am setting correctly the parameter names in my URDF model, specifically the tags under
Thanks,
R.
Asked by ramonvp on 2020-04-08 07:38:47 UTC
I finally found my own answer, just posting it here if by any chance anybody in the future is interested.
The code that really parses this XML file is the sdformat library, source code can be found here: https://bitbucket.org/osrf/sdformat/src/default/
In my case, I cloned the branch 6_to_default.
The exact place where the parsing takes place is in file src/parse_urdf.cc in function line 1215:
void URDF2SDF::ParseSDFExtension(TiXmlDocument &_urdfXml)
Here you will be able to read the exact tags that are supported and parsed. If you follow a suggested answer in a thread and that does not work for you, take into account that some of the examples I have seen are wrong, for example tag self_collide
is not parsed in the gazebo
extension, the correct tag is selfCollide
. Almost the same, but not quite.
Cheers.
Asked by ramonvp on 2020-04-13 06:26:27 UTC
not a full answer, but you might check the SDFormat code, or possible the gazebo_ros_pkgs code
Asked by Peter Mitrano on 2020-04-08 11:00:41 UTC
