Error when trying to run gazebo on macOS Catalina
I try to run gazebo9
on macOS Catalina 10.15.2.
I followed the installation instructions, specifically:
brew tap osrf/simulation
brew install gazebo9
gazebo
When I try to launch gazebo I get the following error:
gazebo --verbose
Gazebo multi-robot simulator, version 9.13.0
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.0.21
[Msg] Could not load the Qt platform plugin "cocoa" in "/usr/local/Cellar/qt/5.14.1/plugins/" even though it was found.
[Err] [GuiIface.cc:123] This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: cocoa, minimal, offscreen, webgl.
I tried to follow suggestions from this SO question by setting QT_QPA_PLATFORM_PLUGIN_PATH=/usr/local/Cellar/qt/5.14.1/plugins/
which is where qt 5 exists after installing it with homebrew. xquartz is also installed using homebrew and works when I enter xeyes
I can also confirm that libqcocoa.dylib
exists in /usr/local/Cellar/qt/5.14.1/plugins/platforms
. And trying with gazebo11
results in the same error.
