Create a camera link inside plugin
asked 2020-04-16 04:47:32 -0500
kumpakri gravatar image
I can see how to create a new link to a robot from Gazebo plugin, but I do not see how to attach a camera to this link. I want to run a plugin that will attach camera to a specified robot and make video as if from the first person perspective as the robot drives around. How can I do that?
2
answered 2020-04-16 12:10:19 -0500
updated 2020-04-21 05:43:13 -0500
I'm working on such a plugin at the moment, and hopefully I'll release it in the next days, gazebo_video_monitor_plugins. Perhaps, it can fit your use case.
But, more specifically on your question...
As a side note, you don't need a new link. It should be enough to just specify a pose inside the camera description, and attach the camera to an existing link. Although, I'm not entirely sure that this is working properly with the camera sensor. But, that's the idea anyway.
The way to create a sensor is by triggering the createSensor event, where you provide the sensor description, the name of the world is which to create the sensor, and the name and id of the link to which to attach the sensor.
#include <gazebo/common/Events.hh>
#include <gazebo/sensors/SensorFactory.hh>
event::Events::createSensor(sdf->GetElement("sensor"), world->Name(),
                            link->GetScopedName(), link->GetId());
This will be picked up by the sensor manager, which it will take care of the rest.
How do you get this camera sensor description? The first parameter must be of type sdf::ElementPtr. I haven't found how to create this element with a text description (such as "<sensor name="camera" type="camera">...</sensor>").
kumpakri gravatar imagekumpakri ( 2020-04-17 08:51:18 -0500 )edit
I define the camera in the plugin configuration. If you really want to have it defined inside the plugin, you can use sdf::initString.
nlamprian gravatar imagenlamprian ( 2020-04-17 08:58:44 -0500 )edit
@nlamprian Thank you! May I ask you how long it took to create this gazebo video package? I'm just curious. This looks like a lot of work.
kumpakri gravatar imagekumpakri ( 2020-04-22 09:07:53 -0500 )edit
I worked on it sporadically for several weeks. It was quite painful, because of all the different ways that gazebo crashes and misbehaves for no obvious reason, while trying to figure out how everything works. It still doesn't do everything I wanted to implement, but at least it records videos successfully.
nlamprian gravatar imagenlamprian ( 2020-04-22 09:42:27 -0500 )edit
Asked: 2020-04-16 04:47:32 -0500
Seen: 215 times
Last updated: Apr 21 '20
