Discrepancy of ray_sensor and gpu_ray sensor - horizontal ray scan
I have the following sensor description (code snippet!) in my robot description:
<sensor name="my_laser_sensor" type="ray">
<ray>
<scan>
<horizontal>
<samples>640</samples>
<resolution>1</resolution>
<min_angle>0</min_angle>
<max_angle>0</max_angle>
</horizontal>
</scan>
</ray>
This sensor works, I get 1 laser beam. Now I need to use a gpuray sensor instead of the raysensor, looking at http://sdformat.org/spec?ver=1.6&elem=sensor#horizontal_samples I am using the default parameters for the ray scan. But when I try to change the type to gpu I get the following error:
EXCEPTION: Camera horizontal field of view invalid.
Even when I remove the horizontal code block, to use the default values by default the error remains.
Why is there a difference between the sensor definitions? How is it possible to simulate a single laser beam with the gpu_sensor?
Thanks!
Using gazebo 9.13
Asked by relffok on 2020-04-16 18:06:46 UTC
Did you resolve this?
Asked by Vitor AMJ on 2020-07-14 16:22:05 UTC
Unfortunately I didn't!
Asked by relffok on 2020-08-22 05:18:32 UTC
