This robot has a joint named "joint2" which is not in the gazebo model
Could any one help me solve this issue, when i launch the robot in Gazebo, the rebot falls to the ground!
Here is my URDF
<?xml version="1.0"?>
<!-- Joints Control in Gazebo -->
<!-- Geometrical properties -->
<!-- Generates a box visual/collision/inertial -->
<xacro:macro name="prism_geometry">
<xacro:insert_block name="origin"/>
<box size="${side} ${side} ${length}"/>
</xacro:macro>
<visual>
<xacro:prism_geometry/>
<material name="orange"/>
<collision>
<mass value="${mass}"/>
<inertia ixx="${(mass/12)*(side*side+length*length)}"
iyy="${(mass/12)*(side*side+length*length)}"
izz="${(mass/6)*(side*side)}"
ixy="0" ixz="0" iyz="0"/>
<!-- Generates a cylinder visual/collision -->
<xacro:macro name="cylinder_geometry">
<cylinder length="${length}" radius="${radius}"/>
</xacro:macro>
<visual>
<xacro:cylinder_geometry/>
<material name="gray"/>
<collision>
<!-- Generates child joint of parent -->
<joint name="${parent}_${child}_joint" type="revolute">
<origin xyz="0 0 ${dist}" rpy="0 0 0"/>
<parent link="${parent}"/>
<child link="${child}"/>
<axis xyz="${axis}"/>
<limit effort="40.0"
velocity="1.0"
lower="${-PI}"
upper="${PI}"/>
<!-- Required for ROS control -->
<transmission name="${parent}_${child}_transmission">
<joint name="${parent}_${child}_joint">
<hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface>
<actuator name="${parent}_${child}_actuator"/>
</transmission>
<link name="${parent}">
<xacro:prism_vci length="${dist}" side="${link_side}">
<origin xyz="0 0 ${dist/2}" rpy="0 0 0"/>
</xacro:prism_vci>
<xacro:cylinder_vc radius="${joint_radius}" length="${joint_length}">
<xacro:if value="${axis=='0 0 1'}">
</xacro:if>
<xacro:if value="${axis=='1 0 0'}">
<origin xyz="0 0 ${dist}" rpy="0 ${PI/2} 0"/>
</xacro:if>
<xacro:if value="${axis=='0 1 0'}">
<origin xyz="0 0 ${dist}" rpy="${PI/2} 0 0"/>
</xacro:if>
</xacro:cylinder_vc>
<gazebo reference="${parent}">
<!-- World frame (for Gazebo) -->
<!-- Arm fixed to world frame -->
<!-- Joints Chain -->
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
filename="package://URDF_robot_complet/meshes/Bras_link_1.STL" />
<material
name="">
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
filename="package://URDF_robot_complet/meshes/Bras_link_2.STL" />
<material
name="">
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
filename="package://URDF_robot_complet/meshes/Bras_link_3.STL" />
<material
name="">
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
filename="package://URDF_robot_complet/meshes/Bras_link_4.STL" />
<material
name="">
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
filename="package://URDF_robot_complet/meshes/Bras_link_5.STL" />
<material
name="">
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
filename="package://URDF_robot_complet/meshes/Effecteur.STL" />
<material
name="">
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
Asked by samir on 2020-04-17 00:08:10 UTC
