How to work with camera image
asked 2020-04-17 08:39:39 -0500
kumpakri gravatar image
updated 2020-04-17 08:40:51 -0500
I am trying to create a sensor plugin for camera sensor. Following the source code for gazebo_ros_camera plugin, I assume, that a CameraPlugin has an OnNewFrame() callback function that is called whenever the camera captures a frame. The callback function than gets the image as const unsigned char *_image. But I do not understand how to get the actual image out of this data type. I want to add some information into each frame, such as simulation time, and then save the frame into a folder. How can this be done?
answered 2020-04-21 02:16:32 -0500
updated 2020-04-21 02:17:35 -0500
I found one way to get the image into cv::Mat format.
#include <cv.h>
void AddSimTimeToFrame::OnNewFrame(const unsigned char *_image,
                                    unsigned int _width,
                                    unsigned int _height,
                                    unsigned int _depth,
                                    const std::string &_format)
    // must be casted to void * to trigger the correct cv::Mat constructor
    void* data = (void*)_image;
    cv::Mat img(_height, _width, CV_8UC3, data);
    // the red and blue channels are switched
    cv::cvtColor(img, img, CV_BGR2RGB);
    // image processing
Asked: 2020-04-17 08:39:39 -0500
Seen: 141 times
Last updated: Apr 21 '20
