(differential controller , teleop )continueous steering of the bot even if button is unpressed
i am controlling a bot with two wheels and 2 castors at front and back, everything seems to be working fine expect the bot keeps steering even if the button is unpressed after a press, it only stops when button "k" is pressed. Please help with the possible reason for such behavior.I already tried changing the friction values of the joint.
Asked by adi on 2020-04-18 11:40:45 UTC
i have the same problem, a single forward /cmd_vel command makes it drive forward indefinetly. wich is a problem because this does not mimic the real robots behavior
Asked by grobax on 2021-04-23 09:27:18 UTC
