DART contact always sets mu2 = 1?
Hello Gazebo-land,
Very quickly:
Here's what I am running:
Gazebo 11.0.0~pre1
on Ubuntu 18.04- Compiled from source according to http://gazebosim.org/tutorials?tut=installfromsource&cat=install
- Included DART support according to install instructions
Here's my .world
file:
<?xml version="1.0" ?>
<sdf version="1.7">
<world name="default">
<physics type="dart">
<max_step_size>0.001</max_step_size>
<real_time_update_rate>1000</real_time_update_rate>
<dart>
<solver>
<solver_type>dantzig</solver_type>
</solver>
<collision_detector>dart</collision_detector>
</dart>
</physics>
<!-- Ground -->
<!-- Cardboard Box -->
<uri>model://cardboard_box/</uri>
<pose>0 0 1 0 0 0</pose>
</world>
Notice that I intend to use DART for physics and collision detection. The model referred to is the standard Gazebo model called cardboard_box
. (I have not included it here.)
Within models/cardboard_box/model.sdf
we set mu
= mu2
= 0.0
<friction>
<ode>
<mu>0.0</mu>
<mu2>0.0</mu2>
</ode>
</friction>
The problem: Once the box is sitting on the ground, we can play with gravity in order to effectively change the inclination of the ground. Two observations:
- [For example] If we set
gravity
(in the order {x,y,z}) to {1.0, 0.0, -9.81}, then the box takes off in the +x-direction due to the frictionless surface. - If we set
gravity
to {0.0, 1.0, -9.81}, the box does not move. In fact, the box will not move for any value for the y-dirgravity
below 9.81. - If we set
gravity
to {0.0, 9.82, -9.81}, the box will start to slowly slide in the +y-direction at a much reduced acceleration.
This behavior suggests that mu2
is being set to a value of 1, regardless of what is in the sdf file.
I'm trying to figure out what is going on, what I'm missing or have set up incorrectly, or if there is a bug.
Thanks for the help.
-GNelson
Asked by GNelson on 2020-04-20 22:51:30 UTC
hello, I think that dart do not use all the parameters provided in the sdf. I ran in a similar issue when I tried to set the max_contact parameter : gazebosim question but unfortunately I didn't receive any answer.
Asked by Clément Rolinat on 2020-04-27 05:38:21 UTC
I should have noted that I'm just using the cardboard_box model as an example. This issue came to my attention because it is affecting any model I use in Gazebo with DART.
Asked by GNelson on 2020-04-20 22:57:19 UTC
