Missing gazebo9 packages in melodic.
After setting up the OSRF repo, I'm unable to install Gazebo 9 on Ubuntu Bionic with ROS Melodic.
docker run -it ros:melodic bash
# apt update
# apt install curl
# curl -sSL http://packages.osrfoundation.org/gazebo.key | apt-key add --yes -
# echo "deb http://packages.osrfoundation.org/gazebo/ubuntu-stable/ bionic main" > /etc/apt/sources.list.d/gazebo-stable.list
# apt update
# apt install ros-melodic-gazebo9-dev
Reading package lists... Done
Building dependency tree
E: Unable to locate package ros-melodic-gazebo9-dev
# apt install ros-melodic-gazebo-dev
... tries to install gazebo11-related packages
This repo directory doesn't show a gazebo9 package, but the gazebo11 package is there: http://packages.osrfoundation.org/gazebo/ubuntu/pool/main/r/ros-melodic-gazebo-dev/
Did Melodic+Gazebo9 support end? Is this just a blip that will get fixed soon?
Asked by dustingooding on 2020-05-01 13:25:34 UTC
