How to set gazebo log dir to a different destination then ~/.gazebo/log
asked 2020-05-03 08:37:34 -0500
altineller gravatar image
I am logging state.log from gazebo-9. But however it insists logging under .gazebo/log.
Is there any way I can set the log dir to a different directory, similar to ROS_LOG_DIR in ros?
Best regards, C.
2
answered 2020-05-03 10:58:07 -0500
chapulina gravatar image
updated 2020-05-04 12:23:51 -0500
If you're logging from the command line, you can pass the --record-path flag.
If you're doing it through the C++ API, you can pass the path to LogRecord::Start.
If you're triggering it through a message, you can use the base_path field.
If you're using ROS 1, pass extra_gazebo_args:="--record-path <path>" to empty_world.launch.
If you're using ROS 2, pass record_path to gzserver.launch.py.
Hello @chapulina I am launching gazebo trough a launch file, in ros. and the ros gazebo arguments do not include record-path. is there a way I can still use ros, and give this command line argument?
best
altineller gravatar imagealtineller ( 2020-05-04 07:44:09 -0500 )edit
I updated the answer to include ROS
chapulina gravatar imagechapulina ( 2020-05-04 12:22:46 -0500 )edit
Asked: 2020-05-03 08:37:34 -0500
Seen: 59 times
Last updated: May 04 '20
