Setting <split_impulse_penetration_threshold> tag of bullet Engine in .world file does not work
Here's the code of the .world file. Whatever I change -0.05 to be, both + and -, the gap between objects in gazebo is always the same and seems -0.01, the default value. But when I add etc. in tag, things do happen. So it confirms gazebo is reading this file. But I cannot figure out why the value of splitimpulsepenetration_threshold is ignored.
<?xml version="1.0" ?>
  <uri>model://sun</uri>
<!-- A ground plane -->
<physics type="bullet">
      <bullet>
        <constraints>
            <contact_surface_layer> 0 </contact_surface_layer>
            <split_impulse> 1 </split_impulse>
            <split_impulse_penetration_threshold> -0.05 </split_impulse_penetration_threshold>
        </constraints>
      </bullet>
</physics>
enter code here
Asked by mazeyu on 2020-05-04 12:42:27 UTC
Very similar problem here. I am trying to modify ground's kp and kd, but nothing happens. I have confirmed the file is correctly read, since with ODE it works.
extract of CODE:
    <surface>
      <contact>
         <collide_bitmask>0xffff</collide_bitmask>
         <ode>
            <kp>1e12</kp>
            <kd>1</kd>
            <min_depth> </min_depth>
         </ode>
         <bullet>
            <kp>1e12</kp>
            <kd>1</kd>
            <split_impulse_penetration_threshold>  </split_impulse_penetration_threshold> <!-- default -0.01 -->
         </bullet>
      </contact>
      <friction>
        <ode>
          <mu>1</mu>
          <mu2>1</mu2>
        </ode>
        <bullet>
          <friction>1</friction>
          <friction2>1</friction2>
        </bullet>
      </friction>
    </surface>
Asked by andrea_pat on 2021-08-28 05:11:15 UTC
