Fixed joint not working properly
asked 2020-05-05 11:21:02 -0600
Hi everyone! I'm new in Gazebo. I created a laser rangefinder model and a robot model in which I want to use it. When I try to fix the imported model with fixed joint or revolute joint with 0 limit, and start the simulation, Gazebo shows the following:
image description
If I don't use any joints, the sensor just falls far down. Without a sensor, the robot looks normal during the simulation, as it should:
image description
Listing of laser model.sdf file:
<?xml version='1.0'?>
<sdf version='1.6'>
  <model name="VL6180">
    <link name='body'>
      <visual name='visual'>
        <pose>-0.0024 -0.0014 0 0 0 0</pose>
          <mesh>
            <uri> model://VL6180/meshes/STL/VL6180X.stl </uri>
            <scale> .001 .001 .001 </scale>
          </mesh>
      <collision name='collision'>
        <pose> 0 0 .0005  0 0 0 </pose>
            <size>.0048 .0028 .001</size>
        <pose>0 0 0 0 0 0</pose>
        <mass>0.00003</mass>
          <ixx>0.00000000000000001</ixx>
          <ixy>0.00000000000000001</ixy>
          <ixz>0.00000000000000001</ixz>
          <iyy>0.00000000000000001</iyy>
          <iyz>0.00000000000000001</iyz>
          <izz>0.00000000000000001</izz>
      <sensor type="ray" name="sensor">
        <pose>0.0018 0 0 0 -1.5708 0</pose>
          <update_rate> 30 </update_rate>
          <ray>
            <scan>
              <horizontal>
                <samples>50</samples>
                <resolution>1</resolution>
                <min_angle>-0.174533</min_angle>
                <max_angle>0.174533</max_angle>
              </horizontal>
              <vertical>
              </vertical>
            </scan>
            <range>
              <min>0.000001</min>
              <max>0.6</max>
            </range>
          </ray>
Listing of robot model.sdf file:
<sdf version='1.6'>
  <model name="my_robot">
    <frame name="robot"></frame>
    <pose>0 0 0.25 0 0 0</pose>
   <!-- <include>
      <name>laser_1</name>
      <uri>model://VL6180</uri>
      <pose>0 0.0425 .003 3.14159 0 3.14159</pose>
    <link name='sole'>
      <pose>0 0 0 1.5708 0 0</pose>
      <visual name='sole_visual'>
          <mesh>
            <uri> model://Robot_model/meshes/STL/Sole.stl </uri>
          </mesh>
      <collision name='sole_collision_box'>
        <pose> 0 .049 0   -1.5708 0 0 </pose>
            <size>.026 .016 .068</size>
      <collision name='sole_collision_cylinder'>
        <pose> 0 .0075 0   -1.5708 0 0 </pose>
          <cylinder>
            <radius>.05</radius>
            <length>.015</length>
          </cylinder>
        <pose>0 .0128 0  0 0 0</pose>
        <mass>.370</mass>
          <ixx>0.000270821</ixx>
          <ixy>0.00</ixy>
          <ixz>0.00</ixz>
          <iyy>0.000402393</iyy>
          <iyz>0.00000</iyz>
          <izz>0.000273382</izz>
    <link name = 'cross'>
      <pose>0 0 0.0725 0 0 1.5708</pose>
      <visual name='cross_visual'>
          <mesh>
            <uri> model://Robot_model/meshes/STL/Cross.stl </uri>
            <scale> .01 .01 .01 </scale>
          </mesh>
      <collision name='cross_collision'>
        <pose> 0 0 .0025 0 0 0 </pose>
            <size>.022 .014 .005</size>
        <pose>0 ...
(more)
answered 2020-05-09 02:22:34 -0600
You need to fix the laser inertia (and fine tune the position of the model).
Try this one (it's the inertia of the collision box)
  <mass>0.03</mass>
    <ixx>2.21000000e-08</ixx>
    <ixy>0.000000</ixy>
    <ixz>0.000000</ixz>
    <iyy>6.01000000e-08</iyy>
    <iyz>0.000000</iyz>
    <izz>7.72000000e-08</izz>
image description
nlamprian, thanks for your answer, its worked! I added this code to inertia tag:
        <pose>0 0 0.0005 0 0 0</pose>
          <ixx>2.21000000e-11</ixx>
          <ixy>0.000000</ixy>
          <ixz>0.000000</ixz>
          <iyy>6.01000000e-11</iyy>
          <iyz>0.000000</iyz>
          <izz>7.72000000e-11</izz>
Aslan_k gravatar imageAslan_k ( 2020-05-10 04:38:08 -0600 )edit
I also wanted to know why Gazebo reacted so much to my past code, and what do you mean by "You need to fix the laser inertia (and fine tune the position of the model)." ?
Aslan_k gravatar imageAslan_k ( 2020-05-10 04:39:20 -0600 )edit
You can think of inertias as the one thing that makes or breaks a model. If something is wrong, your model can collapse or explode. For the position of the laser, in my test, the beams collided with the sole. If it's fine for you, then forget about it.
nlamprian gravatar imagenlamprian ( 2020-05-10 06:55:13 -0600 )edit
Asked: 2020-05-05 11:21:02 -0600
Seen: 701 times
Last updated: May 09 '20
