How to animate a link into a model
Hi all,
I have a model (not an actor) that has links and joint. Let's say I want to put an animation on a special link, showing that a motor is spinning (without changing the velocity of a joint or redefining the model into an actor)
Is it possible to attach an actor or an animation (for example taken from a .dae file) to a link in a model (programmatically if needed)? In this tutorial, it is said that "There can't be models nested inside actors". Is it true the other way? I tried to add an actor inside a model in a SDF file but it doesn't seem to be possible or am I wrong?
Asked by TacticalDalaiLama on 2020-05-08 10:38:51 UTC
