Articulated vehicle control in gazebo and ROS
Hello all, I have an articulated vehicle model in (urdf.xacro) format. The vehicle has two parts (front and rear) connected to each other by a joint. I have established a node (in python) which has:
- a publisher, which publish a new
model pose to the topic
gazebo/set_model_state
. - a service
/gazebo/set_model_configuration
, which controls the position of the joint.
After connecting gazebo to ROS and starting this node, controlling the model was fine. NOW, I have to control each part autonomously (considering each part as a separate model). Therefore,
- I established two xacro files one for each part, thus, I get two models (front model and rear model)
- For each model, I created a launch file
- Finally I created launch file to launch both models together into gazebo. The two models will launch as they were connected to each other.
Afterward, I rewrote the python code to control two models instead of one.
In This node, I am using the topic gazebo/set_model_state
to send new poses of the models.
And I got the following problems:
- If I started gazebo "unpaused" the two models push each other randomly and fly around.
- Even when starting gazebo "paused", when giving an articulated angle command, each model has to change its orientation angle relative to the articulated angle, but only the rear part does that.
I will be very appreciated to get any help from you to solve these problems. Best regards
EDITED: The problem was solved by defining the both model as kinematic models in the xacro files.
Asked by adel on 2020-05-13 04:08:56 UTC
Perhaps the models are constantly in collision therefor trying to get away from each other and "flying around". Perhaps you do not want the parts of the vehicle to collide, because they are actually just one model. Here is a way how to make two gazebo models to ingore the collision between each other http://gazebosim.org/tutorials?tut=collide_bitmask
Asked by kumpakri on 2020-05-18 05:39:21 UTC
Thanks for your answer and sorry for the late response, I tried the way you mentioned but it isn't work. Actually I'm working with URDF not with sdf format and sometimes some properties do not work properly in gazebo. But anyway thanks again for the help and the problem was solved by making the two models as kinematic models
Asked by adel on 2020-05-22 05:46:01 UTC
It would be nice if you could describe how you solved this in an answer to your own question and then click the check button to accept your answer.
Asked by kumpakri on 2020-05-22 07:08:56 UTC
