Light sources make the GUI remain black
Hi there,
I am using Gazebo in Ubuntu installed in a Virtual Machine. I have a dedicated Nvidia GPU that I managed to connect to the VM.
I noticed that including any light source in a .world file, the GUI remains completely black.
This happens if the world contains at least one link, for example a cylinder or simply a box.
However, if I run a .world containing only a light source and a ground plane, i.e.
<?xml version="1.0" ?>
<sdf version="1.5">
    <world name="default">
            <uri>model://sun</uri>
        <!-- A ground plane -->
    </world>
then I correctly visualize the ground plane in an enlightened environment, as you can see in the image below.
image description
Any suggestion to fix this issue? Thank you in advance.
EDIT: with the command --verbose I get the following output message
(gzclient:2324): dbind-WARNING **: 18:25:05.506: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
Asked by Simone on 2020-05-14 11:28:59 UTC
