What does the optical_frame of a camera actually do, for ROS tf transformations?
Hello, I have an Intel Realsense that is spawned in my simulation environment, using a gazebo camera plugin. Among many topics, it has camera_depth_frame and the camera_depth_optical_frame topics that are published.
Visualized in RViz, this is my setup currently. Initial location. To get a better understanding, here is the same setup from a different view. Second view.
Now, when I query the pose transformation between this camera_depth_optical_frame and the world, this is my result.
translation:
  x: 0.318701649258
  y: 0.475529280403
  z: -0.0471259472185
rotation:
  x: 0.499374723815
  y: -0.498611691812
  z: 0.500621423536
  w: 0.501387531058
Looking at the translation values, it does seem fine.
However, when I rotate the entire camera about the y axis, such that it is in this setting Rotated camera, with the camera looking about 1.2 radians down and then query the same transformation, this is my result.
translation:
  x: 0.318701218896
  y: 0.217455112995
  z: 0.400558588204
rotation:
  x: 0.69572986174
  y: -0.694144038039
  z: 0.130472495454
  w: 0.130770569581
Looking at the translation values, it seems very bizarre, since the camera has not actually translated to any other location at all. (other than the very tiny change due to shaking).
This makes me wonder, what actually is this depthopticalframe ?
Note that there is no glitch in my transformation matrices, because if I use the camera_depth_frame rather than the camera_depth_optical_frame, my translation values are the same (which is true)
I am not sure if this query belongs in ROS, or here. I asked here since the optical_frame is a Gazebo plugin.
Thanks
Asked by Shrutheesh R Iyer on 2020-05-16 05:26:14 UTC
