Sensor output to ignition topic not working for depth_camera and gpu_ray
Hi, I'm trying to simulate a realsense type model using the built-in gazebo sensors and to output on ignition topics. In the model below, I have a number of camera frames, but I find that only rgb camera topics are produced. Depth Topics are not available and no point clouds are produced by gpu_ray.
Additionlly, gazebo complains of
[Wrn] [msgs.cc:1841] Conversion of sensor type[gpu_ray] not supported.
[Wrn] [msgs.cc:1841] Conversion of sensor type[depth_camera] not supported.
and
ign topic -l only shows the following topics:
/default/d435slam/base_link/camera_left_ir_frame_camera/image
/default/d435slam/base_link/camera_link_camera/image
/default/d435slam/base_link/camera_right_ir_frame_camera/image
/introspection/jxwlfx/items_update
I am using Gazebo 11 and sdf 1.7.
This is my sdf file:
<sdf version='1.7'>
  <model name='d435slam'>
    <link name='base_link'>
        <pose>0 0 0 0 -0 0</pose>
        <mass>0.564</mass>
          <ixx>0.00388124</ixx>
          <iyy>0.00049894</iyy>
          <izz>0.00387926</izz>
      <collision name='base_link_fixed_joint_lump__camera_link_collision'>
        <pose>0 0 0.0125 0 -0 0</pose>
            <size>0.02505 0.09 0.025</size>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      <visual name='base_link_fixed_joint_lump__camera_link_visual'>
        <pose>0.0149 0 0.0125 1.5708 -0 1.5708</pose>
          <mesh>
            <scale>1 1 1</scale>
            <uri>model://d435slam/meshes/d435.dae</uri>
          </mesh>
          <script>
            <name>Gazebo/Black</name>
          </script>
      <velocity_decay/>
      <velocity_decay/>
      <sensor name='camera_link_camera' type='camera'>
        <topic>rgb_cam</topic>
          <horizontal_fov>1</horizontal_fov>
            <width>640</width>
            <height>480</height>
            <far>700</far>
      <velocity_decay/>
      <sensor name='depth_point_cloud' type='gpu_ray'>
        <topic>points</topic>
        <ray>
          <scan>
            <horizontal>
              <samples>48</samples>
              <resolution>1</resolution>
              <min_angle>-0.6</min_angle>
              <max_angle>0.6</max_angle>
            </horizontal>
            <vertical>
              <samples>36</samples>
              <min_angle>-0.5</min_angle>
              <max_angle>0.5</max_angle>
            </vertical>
          </scan>
          <range>
            <min>0.2</min>
            <max>40</max>
          </range>
          <noise>
            <type>gaussian</type>
            <mean>0</mean>
            <stddev>0.01</stddev>
          </noise>
        </ray>
        <pose>0.0149 0.0175 0.0125 0 -0 0</pose>
      <velocity_decay/>
      <sensor name='camera_left_ir_frame_camera' type='camera'>
        <topic>ir_left</topic>
            <width>640</width>
            <far>700</far>
      <velocity_decay/>
      <sensor name='depth_camera' type='depth_camera'>
        <topic>depth_camera</topic>
            <width>640</width>
          <depth_camera>
              <far>50</far>
            <output>depths</output>
          </depth_camera>
      <gravity>1</gravity>
      <velocity_decay/>
      <sensor name='camera_right_ir_frame_camera' type='camera'>
        <topic>ir_right</topic>
            <width>640</width>
            <far>700</far>
        <pose>0.0149 -0.0325 0.0125 0 -0 0</pose>
Asked by PMilani on 2020-05-17 07:58:45 UTC
