Multiple Ray Sensors - Interference?
Hi there,
I added multiple single ray sensors to my robot using the appended xacro. I then instantiated three of them, one in the middle, one to the right and one to the left, I appended the code for that too.
The problem is: somehow the left and the right sensor are affected by the one in the middle. If the one in the middle is detecting something, than also the others show the same values. Furthermore: the sensor to the left and the one to the right do have a really strange behaviour, let me show that to you:
C:\fakepath\Screen Captureselect-area20200522223754.gif
It looks like those three sensors somehoe interfere internally - but why?
<link name="${link_name}">
<mass value="${mass}" />
<xacro:cylinder_inertia m="0.01" r="${radius}" h="${height}" />
<visual>
<origin xyz="0 0 0" rpy="${rpy}"/>
<cylinder radius="${radius}" length="${height}"/>
<material name="sensor_red" />
<collision>
<origin xyz="0 0 0" rpy="${rpy}" />
<joint name="joint_${link_name}" type="fixed">
<origin xyz="${xyz}" rpy="0 0 0"/>
<parent link="${parent_name}"/>
<child link="${link_name}"/>
<gazebo reference="${link_name}">
<sensor type="ray" name="${link_name}_sensor">
<topic>/sensors/${link_name}</topic>
<plugin name="${link_name}_controller" filename="libgazebo_ros_laser.so">
<topicName>/sensors/${link_name}</topicName>
<frameName>${link_name}</frameName>
<ray>
<scan>
<horizontal>
<samples>1</samples>
<resolution>1</resolution>
<min_angle>${min_angle*(pi/180)}</min_angle>
<max_angle>${max_angle*(pi/180)}</max_angle>
</horizontal>
</scan>
<!-- Laser Range Finder Bricklet (Tinkerforge) -->
<range>
<min>0.1</min> <!-- 0.05 -->
<max>40.0</max>
<resolution>0.01</resolution>
</range>
<noise>
<type>gaussian</type>
<mean>0.0</mean>
<stddev>0.01</stddev>
</noise>
</ray>
Instantiation:
<!-- Laser Sensors -->
<xacro:distance_sensor
link_name="sensor_laser"
parent_name="chassis"
mass="0.01" radius="0.015" height="0.1"
xyz="0.25 0 0" rpy="0.00 1.5708 0.00"
min_angle="0" max_angle="0"
<!-- US Sensor Left -->
link_name="sensor_us_l"
xyz="0.25 0.05 0" rpy="-1.0472 1.5708 0.00"
min_angle="60" max_angle="60"
<!-- US Sensor Right -->
link_name="sensor_us_r"
xyz="0.25 -0.05 0" rpy="1.0472 1.5708 0.00"
min_angle="-60" max_angle="-60"
Asked by flodo on 2020-05-22 15:47:43 UTC
As you can see, there is a bug in Gazebo which is related to Resolution / Samples ratio. I fixed it by using two samples.
furthermore, if you specify min_angle = max_angle, then it is alsways measuring to 0 degrees, no matter which angle is specified.
Asked by flodo on 2020-05-26 17:06:44 UTC
