URDF doesnt load in Gazebo 9
Hi all,
I have been trying to load my URDF of a Commonplace Robotics Mover6 into Gazebo from RViz. I have tried to follow this tutorial to the best of my knowledge and created the suggested file structure, world etc.
Unfortunately, when I run the launch file, Gazebo boots up, but the robot can not be seen. If I click on it in the file tree on the left-hand side, the whole program crashes, stating the following:
libcurl: (51) SSL: no alternative certificate subject name matches target host name 'api.ignitionfuel.org'
gzclient: /build/ogre-1.9-B6QkmW/ogre-1.9-1.9.0+dfsg1/OgreMain/include/OgreAxisAlignedBox.h:252: void Ogre::AxisAlignedBox::setExtents(const Ogre::Vector3&, const Ogre::Vector3&): Assertion
(min.x <= max.x && min.y <= max.y && min.z <= max.z) && "The minimum corner of the box must be less than or equal to maximum corner"' failed.
Aborted (core dumped)
[gazebogui-2] process has died [pid 27467, exit code 134, cmd /opt/ros/melodic/lib/gazeboros/gzclient _name:=gazebogui _log:=/home/lee/.ros/log/53b56330-a4e1-11ea-a9e0-0c9d92c25afd/gazebogui-2.log].
log file: /home/lee/.ros/log/53b56330-a4e1-11ea-a9e0-0c9d92c25afd/gazebo_gui-2*.log
My Launch File:
<launch>
<!-- We resume the logic in empty_world.launch, changing only the name of the world to be launched -->
<arg name="world_name" value="$(find mover6_gazebo)/worlds/mover6.world"/>
<!-- more default parameters can be changed here -->
<!-- Convert an xacro and put on parameter server -->
<param name="robot_description" command="$(find xacro)/xacro.py $(find mover6_description)/urdf/mover6.urdf.xacro" />
<!-- Spawn a robot into Gazebo -->
<node name="spawn_urdf" pkg="gazebo_ros" type="spawn_model" args="-param robot_description -urdf -model mover6" />
</launch>
My World File:
<?xml version="1.0" ?>
<sdf version="1.4">
<world name="default">
<uri>model://sun</uri>
<uri>model://gas_station</uri>
<name>gas_station</name>
<pose>-2.0 7.0 0 0 0 0</pose>
</world>
My URDF:
<?xml version="1.0"?>
<robot xmlns:xacro="http://ros.org/wiki/xacro" name="CPRMover6">
<!-- URDF file for the Commonplace Robotics Mover4 robot arm -->
<!-- Version 1.1 from Oct. 04th, 2016. -->
<link name="base_link">
<visual>
<origin rpy="0 0 0" xyz="0 0 0"/>
<mesh filename="package://mover6_description/meshes/Joint0.dae" scale="0.001 0.001 0.001"/>
<collision>
<mesh filename="package://mover6_description/meshes/Joint0Coll.dae" scale="0.001 0.001 0.001"/>
<mass value="1"/>
<inertia
ixx="1.0" ixy="1.0" ixz="1.0"
iyy="1.0" iyz="1.0"
izz="1.0"/>
<link name="link1">
<visual>
<mesh filename="package://mover6_description/meshes/Joint1.dae" scale="0.001 0.001 0.001"/>
<collision>
<mesh filename="package://mover6_description/meshes/Joint1Coll.dae" scale="0.001 0.001 0.001"/>
<mass value="1"/>
<inertia
iyy="1.0" iyz="1.0"
izz="1.0"/>
<link name="link2">
<visual>
<mesh filename="package://mover6_description/meshes/Joint2.dae" scale="0.001 0.001 0.001"/>
<collision>
<mesh filename="package://mover6_description/meshes/Joint2Coll.dae" scale="0.001 0.001 0.001"/>
<mass value="1"/>
<inertia
iyy="1.0" iyz="1.0"
izz="1.0"/>
<link name="link3">
<visual>
<mesh filename="package://mover6_description/meshes/Joint3.dae" scale="0.001 0.001 0.001"/>
<collision>
<mesh filename="package://mover6_description/meshes/Joint3Coll.dae" scale="0.001 0.001 0.001"/>
<mass value="1"/>
<inertia
iyy="1.0" iyz="1.0"
izz="1.0"/>
<link name="link4">
<visual>
<mesh filename="package://mover6_description/meshes/Joint4.dae" scale="0.001 0.001 0.001"/>
<collision>
<mesh filename="package://mover6_description/meshes/Joint4Coll.dae" scale="0.001 0.001 0.001"/>
<mass value="1"/>
<inertia
iyy="1.0" iyz="1.0"
izz="1.0"/>
<link name="link5">
<visual>
<mesh filename="package://mover6_description/meshes/Joint5.dae" scale="0.001 0.001 0.001"/>
<collision>
<mesh filename="package://mover6_description/meshes/Joint5Coll.dae" scale="0.001 0.001 0.001"/>
<mass value="1"/>
<inertia
iyy="1.0" iyz="1.0"
izz="1.0"/>
<link name="link6">
<visual>
<mesh filename="package://mover6_description/meshes/Joint6.dae" scale="0.001 0.001 0.001"/>
<collision>
<mesh filename="package://mover6_description/meshes/Joint6Coll.dae" scale="0.001 0.001 0.001"/>
<mass value="1"/>
<inertia
iyy="1.0" iyz="1.0"
izz="1.0"/>
<joint name="joint1" type="continuous">
<axis xyz="0 0 -1"/>
<parent link="base_link"/>
<child link="link1"/>
<origin rpy="0 0 0" xyz="0 0 0.130"/>
<limit effort="100" velocity="30"/>
<joint_properties damping="0.0" friction="0.0"/>
<joint name="joint2" type="continuous">
<axis xyz="0 1 0"/>
<parent link="link1"/>
<child link="link2"/>
<origin rpy="0 0 0" xyz="0 0 0.0625"/>
<joint name="joint3" type="continuous">
<axis xyz="0 1 0"/>
<parent link="link2"/>
<child link="link3"/>
<origin rpy="0 1.57079632679 0" xyz="0 0 0.190"/>
<joint name="joint4" type="continuous">
<axis xyz="0 0 1"/>
<parent link="link3"/>
<child link="link4"/>
<origin rpy="0 0 0" xyz="-0.06 0 0"/>
<joint name="joint5" type="continuous">
<axis xyz="0 1 0"/>
<parent link="link4"/>
<child link="link5"/>
<origin rpy="0 0 0" xyz="0 0 0.290"/>
<joint name="joint6" type="continuous">
<axis xyz="0 0 1"/>
<parent link="link5"/>
<child link="link6"/>
<origin rpy="0 0 0" xyz="0 0 0.055"/>
</robot>
Has anyone got any ideas why it may not be loading?
Asked by sevenPillars on 2020-06-02 11:00:25 UTC
