URDF to SDF: Duplicate Physics Tags
Hi all,
I am trying to convert the following URDF into SDF using gz sdf -p model.urdf > model.sdf. I am trying to make sure the implicit spring damper is set to 1 through a gazebo reference. But in the output i get a duplicate.
INPUT URDF
<?xml version="1.0" ?>
<robot name="iris">
  <origin rpy="0 0 0" xyz="0    0     0.194923"/>
  <link name="base_link">
      <mass value="1.5"/>
      <origin rpy="0 0 0" xyz="0 0 0"/>
      <inertia ixx="0.008" ixy="0" ixz="0" iyy="0.015" iyz="0" izz="0.017"/>
    <collision name="base_link">
      <origin rpy="0 0 0" xyz="0      0      -0.08"/>
        <box size="0.47 0.47 0.23"/>
    <visual name="base_link">
        <mesh filename="package://pysdf/scripts/meshes/iris.dae" scale="1.0 1.0 1.0"/>
  <link name="rotor_0">
      <mass value="0.025"/>
      <inertia ixx="9.75e-06" ixy="0" ixz="0" iyy="0.000166704" iyz="0" izz="0.000167604"/>
    <collision name="rotor_0">
        <cylinder length="0.005" radius="0.1"/>
    <visual name="rotor_0">
        <mesh filename="package://pysdf/scripts/meshes/iris_prop_ccw.dae" scale="1 1 1"/>
  <joint name="rotor_0_joint" type="revolute">
    <parent link="base_link"/>
    <child link="rotor_0"/>
    <origin rpy="0 0 0" xyz="0.13    -0.22     0.023"/>
    <axis xyz="0 0 1"/>
    <dynamics damping="0.004"/>
    <limit effort="-1" lower="-1e+16" upper="1e+16" velocity="-1"/>
  <gazebo reference="rotor_0">
    <collision name='rotor_0_collision'>
      <surface>
        <contact>
          <ode/>
        </contact>
        <friction>
          <ode/>
        </friction>
      </surface>
    <visual name='rotor_0_visual'>
        <script>
          <name>Gazebo/Blue</name>
          <uri>__default__</uri>
        </script>
  <gazebo reference="rotor_0_joint">
    <physics>
      <ode>
         <implicit_spring_damper>1</implicit_spring_damper>
      </ode>
    </physics>
</robot>
The generated SDF returns multiple physics tags. Is it possible to combine them into the one tag upon upon conversion from URDF to SDF?
OUTPUT SDF (partial)
<joint name='rotor_0_joint' type='revolute'>
  <child>rotor_0</child>
  <parent>base_link</parent>
  <axis>
    <xyz>0 0 1</xyz>
    <limit>
      <lower>-1e+16</lower>
      <upper>1e+16</upper>
      <effort>-1</effort>
      <velocity>-1</velocity>
    </limit>
    <dynamics>
      <damping>0.004</damping>
      <friction>0</friction>
    </dynamics>
    <use_parent_model_frame>1</use_parent_model_frame>
  </axis>
  <physics>
    <ode>
      <limit>
        <cfm>0</cfm>
        <erp>0.2</erp>
      </limit>
    </ode>
  </physics>
  <physics>
    <ode>
    </ode>
  </physics>
Notice there are TWO physics tags! Does Gazebo9 automatically merge the two Physics tags and their contents together or does it only read one of them?
Thanks
Asked by adcurry on 2020-06-12 22:58:00 UTC
I would assume that it works but i haven't tested it. I would follow the SDF docs: link text and write it into one Element.
Asked by stephanr on 2020-06-13 02:49:17 UTC
