Why does gravity not simulate?
I am trying to make a quadruped robot. I have attached the files of the robot below. It says that gravity cannot be simulated correctly. What should I do to correct it. Also, it says
[ INFO] [1592469924.035582306, 0.001000000]: Starting gazebo_ros_control plugin in namespace: /urdfgenesyssw
[ INFO] [1592469924.037038323, 0.001000000]: gazebo_ros_control plugin is waiting for model URDF in parameter [/robot_description] on the ROS param server.
[ERROR] [1592469924.154172441, 0.001000000]: No p gain specified for pid. Namespace: /gazebo_ros_control/pid_gains/BLLFT
The error occurs even when I have included a yaml file with joint config details with PID parameters, Ill attach a sample below.C:\fakepath\gazebo.launch
The below warning occurs but I have no idea why.
[ INFO] [1592469924.177225326, 0.001000000]: Loaded gazebo_ros_control.
[ WARN] [1592469924.177853816, 0.002000000]: The default_robot_hw_sim plugin is using the Joint::SetPosition method without preserving the link velocity.
[ WARN] [1592469924.177892672, 0.002000000]: As a result, gravity will not be simulated correctly for your model.
[ WARN] [1592469924.177916895, 0.002000000]: Please set gazebo_pid parameters, switch to the VelocityJointInterface or EffortJointInterface, or upgrade to Gazebo 9.
[ WARN] [1592469924.177943573, 0.002000000]: For details, see https://github.com/ros-simulation/gazebo_ros_pkgs/issues/612
I am also attaching the YAML FILE CODE.
# Publish all joint states
joint_state_controller:
type: joint_state_controller/JointStateController
publish_rate: 50
# Position Controllers
joint11_position_controller:
type: effort_controllers/JointPositionController
joint: base_link_to_LF_thigh_link
pid: {p: 200.0, i: 10, d: 10.0}
joint12_position_controller:
joint: LF_thigh_link_to_LF_calf_link
joint21_position_controller:
joint: base_link_to_RF_thigh_link
joint22_position_controller:
joint: RF_thigh_link_to_RF_calf_link
joint31_position_controller:
joint: base_link_to_LH_thigh_link
joint32_position_controller:
joint: LH_thigh_link_to_LH_calf_link
joint41_position_controller:
joint: base_link_to_RH_thigh_link
joint42_position_controller:
joint: RH_thigh_link_to_RH_calf_link
Asked by isaacasimov on 2020-06-18 04:14:38 UTC
