Cannot spawn a model correctly in Gazebo despite looking good in RViz and check_urdf
I am having trouble loading the model in Gazebo using the urdf file. The model looks good in Rviz Viewer and while using the command check_urdf
. The model I am trying to spawn is a humanoid model with 48 DoFs. I have checked the forum but to me, there aren't many queries asked supporting the biped robots.
What I did is,
The frames for two or more DoFs in the shoulder joint (say) has been loaded with dummy links. But I had set <mass>
and <inertia>
to the dummy links. Though for initial testing purposes, I am using the mass and inertia values as same for the dummy links and the actual links itself (Please correct me if I am wrong).
If I am trying to remove the dummy links from the model, I cannot view the model in Rviz. So I think I have no other go than keeping the dummy links to the urdf.
I am adding the reference images below:
Gazebo screenshot
Rviz Screenshot
Here, you can see only one link is visible in Gazebo. I don't know what the issue is. Can somebody help me with this? If so, it would be a great help for me to proceed. Also, if there's an alternate solution for this case, it would greatly help me.
I am attaching the sample of the URDF file below.
<robot name="human model">
<link name="Pelvis">
<mass value="6.032"/>
<origin xyz="0 0 0.05412" rpy="0 0 0" />
<inertia ixx="0.044245" iyy="0.017009" izz="0.050738" ixy="0" ixz="0" iyz="0"/>
<visual>
<box size="0.1529 0.2785 0.10227"/>
<collision>
<link name="L5_f1">
<mass value="0"/>
<inertia ixx="0" iyy="0" izz="0" ixy="0" ixz="0" iyz="0"/>
<link name="L5">
<mass value="7.6908"/>
<!--COM origin wrt jL5S1-->
<origin xyz="0 0 0.045123" rpy="0 0 0" />
<inertia ixx="0.026136" iyy="0.020203" izz="0.0359" ixy="0" ixz="0" iyz="0"/>
<visual>
<box size="0.1529 0.18065 0.090247"/>
<collision>
<joint name="jL5S1_rotx" type="revolute">
<origin xyz="-0.000609 0 0.10526" rpy="0 0 0"/>
<parent link="Pelvis"/>
<child link="L5_f1"/>
<dynamics damping="0.1" friction="0.0"/>
<limit effort="30" velocity="1.0" lower="-0.610865" upper="0.610865" />
<axis xyz="1 0 0" />
Asked by franklin_selva on 2020-06-19 06:20:57 UTC
Could you share the URDF file? Then we could have some idea.
Asked by isaacasimov on 2020-06-20 04:16:53 UTC
@isaacasimov I have edited the question with a sample of the URDF. Kindly check.
Asked by franklin_selva on 2020-06-20 08:41:17 UTC
