The laser scanner shows vertically.
Hello. I have some problems with the lidar in Gazebo, he visualizes his viewing angle vertically (photo below). image description I understand that the problem is most likely in the urdf file and coordinates, but when changing the coordinates of the rpu, the position of the lidar relative to the base changes and becomes incorrect. I put the file description of the lidar and urdf. I use ubuntu 16.04, gazebo 7, ROS kinetic.
<gazebo reference="lidar_Link">
<sensor type="gpu_ray" name="head_hokuyo_sensor">
  <pose>0 0 0 1.57 0 0</pose>
  <update_rate>40</update_rate>
  <ray>
    <scan>
      <horizontal>
        <samples>720</samples>
        <resolution>1</resolution>
        <min_angle>-1.57</min_angle>
        <max_angle>1.57</max_angle>
      </horizontal>
    </scan>
    <range>
      <min>0.10</min>
      <max>30.0</max>
      <resolution>0.01</resolution>
    </range>
    <noise>
      <type>gaussian</type>
      <!-- Noise parameters based on published spec for Hokuyo laser
           achieving "+-30mm" accuracy at range < 10m.  A mean of 0.0m and
           stddev of 0.01m will put 99.7% of samples within 0.03m of the true
           reading. -->
      <mean>0.0</mean>
      <stddev>0.01</stddev>
    </noise>
  </ray>
  <plugin name="gazebo_ros_head_hokuyo_controller" filename="libgazebo_ros_gpu_laser.so">
    <topicName>lidar</topicName>
    <frameName>lidar_Link</frameName>
  <link
    name="lidar_Link">
      <origin
        xyz="-0.00748448520155036 0.0107642484685222 9.23258810867893E-05"
        rpy="0 0 0" />
       <mass
        value="1.32500692137329" />
      <inertia
        ixx="0.000608332242778497"
        ixy="0.000158213161725828"
        ixz="8.018601126292E-07"
        iyy="0.00108767494554066"
        iyz="3.10338854918562E-06"
        izz="0.000950463889297707" />
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://my_robot8/meshes/lidar_Link.STL" />
      <material
        name="">
        <color
          rgba="0.792156862745098 0.819607843137255 0.933333333333333 1" />
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
  <joint
    name="lidar_Joint"
    type="fixed">
    <origin
      xyz="-0.00130997440115162 0.00362996782486146 0.083412672552623"
      rpy="1.57834120194613 -0.0293512866690902 1.57" />
    <parent
      link="base_link" />
    <child
      link="lidar_Link" />
    <axis
      xyz="0 0 0" />
Sorry for the visualization of the code, some problems...with my hands. Thanks in advance for your help!
Asked by Ilya_novichok on 2020-06-20 15:47:53 UTC
