Plotting Tool Only Plots 10000 Points
It appears that the built-in plotting utility only plots the most recent 10000 points as a default. As a result, the larger the value of real_time_update_rate
the less simulation time is plotted (2 seconds at 5000, 1 second at 10000, etc). Is there a way to increase this limit and have the plotting utility display more points?
Asked by rknopf on 2020-06-25 21:35:28 UTC
I see you also ticketed an issue: https://github.com/osrf/gazebo/issues/2777#issuecomment-678673464
Asked by chapulina on 2020-08-25 17:18:20 UTC
