GAZEBO_PLUGIN_PATH different for plugins?
I am using the package from
https://bitbucket.org/theconstructcor...
And I am trying to modify the sjtudrone package to include a depth camera, so I modified the sjtudrone.sdf to have:
<sensor name="camera" type="depth">
<update_rate>20</update_rate>
<horizontal_fov>1.047198</horizontal_fov>
<width>640</width>
<height>480</height>
<format>R8G8B8</format>
<near>0.05</near>
<far>3</far>
<plugin name="camera_plugin" filename="libgazebo_ros_openni_kinect.so">
<baseline>0.2</baseline>
<alwaysOn>true</alwaysOn>
<!-- Keep this zero, update_rate in the parent <sensor> tag
will control the frame rate. -->
<updateRate>0.0</updateRate>
<cameraName>camera_ir</cameraName>
<imageTopicName>/camera/color/image_raw</imageTopicName>
<cameraInfoTopicName>/camera/color/camera_info</cameraInfoTopicName>
<depthImageTopicName>/camera/depth/image_raw</depthImageTopicName>
<depthImageCameraInfoTopicName>/camera/depth/camera_info</depthImageCameraInfoTopicName>
<pointCloudTopicName>/camera/depth/points</pointCloudTopicName>
<frameName>camera_link</frameName>
<pointCloudCutoff>0.5</pointCloudCutoff>
<pointCloudCutoffMax>3.0</pointCloudCutoffMax>
<distortionK1>0</distortionK1>
<distortionK2>0</distortionK2>
<distortionK3>0</distortionK3>
<distortionT1>0</distortionT1>
<distortionT2>0</distortionT2>
<CxPrime>0</CxPrime>
<Cx>0</Cx>
<Cy>0</Cy>
<focalLength>0</focalLength>
<hackBaseline>0</hackBaseline>
I put these under the downcamera plugins, however, when I rostopic list, all the topics I specified in the cameraplugin did not show up.
Any tips on how to solve this issue? Thank you.
update: I noticed that, when I removed this line from start_gaserver:
export GAZEBOPLUGINPATH=$packpath/plugins:$GAZEBOPLUGIN_PATH
Then the Kinect camera can publish topics, but the drone topics are missing. On contrast, when I include this line, I got the drone topics but not the Kinect topics.
Asked by kolohe113 on 2020-07-09 16:29:32 UTC
