Rendering issue with custom collada model
For the purpose of my simulation, I have created a custom 3D model.
When I start gazebo with my world in my "/usr/share/gazebo-11/worlds" folder:
gazebo test.world
<?xml version="1.0"?>
<sdf version="1.4">
  <world name="default">
      <uri>model://sun</uri>
      <uri>model://my_model</uri>
  </world>
The model is loaded but appears entirely black.
image description
When I load the .dae file directly in the world file:
<model name="my_model">
      <link name="body">
            <mesh><uri>file://my_model.dae</uri></mesh>
The model is invisible, it appears on the left panel under the "models" section but that's it.
However, when I use the same code as above, in a random folder such as Documents, the model is loaded and looks exactly as it should:
image description
My model's folder is located in /usr/share/gazebo-11/models:
my_model/
├── meshes
│   └── my_model.dae
├── model.config
└── model.sdf
Whenever I tried to directly import I made sure the dae file was present in the folder I was calling gazebo from
I am running out of ideas to troubleshoot this issue.. I suspect there is an issue with the paths within my files but I don't know... Does someone have any suggestions ?
Asked by R6 on 2020-07-13 08:16:49 UTC
.dae file = mesh+ texture
model = xml file + config file with all the tags gazebo needs for simulation
put
    <pose>0 0 0 0 0 0</pose>
into the world file.
and check that you have correctly set GAZEBO_MODEL_PATH and GAZEBO_RESOURCE_PATH
for example by:
printenv | grep GAZEBO
I suggest separating model directories and mesh directories and add model directory to GAZEBO_MODEL_PATH and and world&mesh directories to GAZEBO_RESOURCE_PATH
Asked by martinerk0 on 2021-05-31 06:52:44 UTC
