Getting Gazebo 11 running on WSL2 on Windows 10
I'm trying to get Gazebo 11 up and running on WSL2 in Windows 10 (running Ubuntu 20.04), having followed these instructions. I get to the very end of the instructions and run gazebo
, and subsequently get this error:
gzclient: error while loading shared libraries: libQt5Core.so.5: cannot open shared object file: No such file or directory
Running this command dpkg -l | grep libqt5
I've verified that the QT5 libraries are all correctly installed:
ii libqt5core5a:amd64 5.12.8+dfsg-0ubuntu1 amd64 Qt 5 core module
ii libqt5dbus5:amd64 5.12.8+dfsg-0ubuntu1 amd64 Qt 5 D-Bus module
ii libqt5gui5:amd64 5.12.8+dfsg-0ubuntu1 amd64 Qt 5 GUI module
ii libqt5network5:amd64 5.12.8+dfsg-0ubuntu1 amd64 Qt 5 network module
ii libqt5opengl5:amd64 5.12.8+dfsg-0ubuntu1 amd64 Qt 5 OpenGL module
ii libqt5svg5:amd64 5.12.8-0ubuntu1 amd64 Qt 5 SVG module
ii libqt5widgets5:amd64 5.12.8+dfsg-0ubuntu1 amd64 Qt 5 widgets module
Running find /usr -name libQt5Core.so.5
yields /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
Has anyone encountered this problem before with QT5 on WSL2 and found a solution ?
Asked by alex.marshall.peg on 2020-07-14 16:35:00 UTC
This can be solution. You can sent me an e-mail, semihbeycimen@gmail.com
sudo strip --remove-section=.note.ABI-tag /usr/lib64/libQt5Core.so.5
or
sudo strip --remove-section=.note.ABI-tag /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
Asked by semih on 2021-02-16 11:51:17 UTC
