Running gzserver on remote machine using ssh
Hi!
I'm trying to run gzserver on a remote machine.
If I simply do
ssh machine
gzserver --verbose
This is the result:
[Err] [RenderEngine.cc:734] Can't open display:
[Wrn] [RenderEngine.cc:97] Unable to create X window. Rendering will be disabled
[Wrn] [RenderEngine.cc:301] Cannot initialize render engine since render path type is NONE. Ignore this warning ifrendering has been turned off on purpose.
So I've tried using (ssh-ing from a vmware)
ssh -X machine
gzserver --verbose
The output is, crashing
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  155 (GLX)
  Minor opcode of failed request:  3 (X_GLXCreateContext)
  Value in failed request:  0x0
  Serial number of failed request:  18
  Current serial number in output stream:  19
I also tried to install Xvfb and run
Xvfb :5 -screen 0 1024x768x24 &
export DISPLAY=:5.0
gzserver --verbose
no help, same error
  Major opcode of failed request:  151 (GLX)
Any clues on why this might be happening?
Asked by marinamrr on 2020-07-16 16:18:57 UTC
