How to set the distance between points in pointclouds
I am using gazebo depth kinect camera plugin to display my pointclouds. I was wondering if there is any ways that I can set the distance between points in the pointcloud itself. For example beam spacing is: 0.39 degree (horizontal) and 0.19 degree (vertical).
Asked by lucien on 2020-07-26 22:32:27 UTC
With the depth kinect camera plugin you can change: widht, height, FOV and some others. But you can try with other type of sensor, for example range sensor. This will generate the cloud but not the RGB data.
<ray>
<scan display="true">
<horizontal>
<samples>641</samples>
<resolution>1.0</resolution>
<min_angle>-0.5</min_angle>
<max_angle>0.5</max_angle>
</horizontal>
<!--vertical samples="1" resolution="1.0" min_angle="-0.5236" max_angle="0.5236" /-->
</scan>
<range>
<min>0.15</min>
<max>30.0</max>
</range>
</ray>
Asked by ahcorde on 2020-07-27 08:18:19 UTC
