2
Proper way to set the size.z of <heightmap><size></size><heightmap>
asked 2020-07-27 16:23:42 -0500
To put things into context I have a DEM stored in a geotiff with proper gdal metadata set, I am using Gazebo9.
Let's say the DEM has max_elevation of 5.0 and and a min_elevation value of 1.0.
How do I correctly set the value of z_scale value (shown below) if I want to maintain the same height values stored in the dem?
<heightmap><size>desired_width desired_height z_scale</size></heightmap>
By examining https://github.com/osrf/gazebo/blob/g... and https://github.com/osrf/gazebo/blob/g... gazebo seems to use the following formula (max_elevation-min_elevation)/max_elevation, this means that z_scale would be (5.0-1.0)/5.0=0.8.
I read somewhere that I should be using the formula max_elevation-min_elevation which mean the z_scale value would 5.0-1.0=4.0. Is this correct?
Also how much reliable is the GDAL metadata parsing code within Gazebo9. Can I just rely on that?
how much reliable is the GDAL metadata parsing code within Gazebo9. Can I just rely on that? If you explicitly set <size>, gazebo will use that, but if not it will infer the size from the DEM file. I haven't done benchmarking on its accuracy or tested for bugs, but I will be happy to investigate any bug reports about it. https://github.com/osrf/gazebo/blob/g...
scpeters gravatar imagescpeters ( 2020-08-07 18:30:42 -0500 )edit
@scpeters At one point, I tried omitting the <size> for a tiff height-map that had associated geo-reference information, gazebo loads the map with proper elevation (I measured that) but the desired_width & desired_height was not in line with the geo-reference information. The map had a size of 5mx5m but gazebo gave me 20mx20m. How do I report a bug?
Samahu gravatar imageSamahu ( 2020-08-12 15:48:01 -0500 )edit
answered 2020-08-06 15:17:35 -0500
lakshmi gravatar image
You should be using the formula max_elevation-min_elevation which mean the z_scale value would 5.0-1.0=4.0.
yes, I believe this is the right way to compute the scale, which should have units of length
scpeters gravatar imagescpeters ( 2020-08-07 18:25:04 -0500 )edit
Asked: 2020-07-27 16:23:42 -0500
Seen: 369 times
Last updated: Aug 06 '20
