Any C++ example for DRCSIM v2.5?
asked 2013-04-25 11:23:04 -0600
Luis Filipe Rossi gravatar image
Just could find examples for python at DRCSIM v2.5 and my old C++ ROS node is not working anymore as we should disable BDI control and use AtlasCommands and not JointCommands anymore... There is any workaround for this problem?
answered 2013-04-26 11:52:00 -0600
gerkey gravatar image
There's a new tutorial for the forthcoming drcsim 2.6 that's in C++. That should mostly work for you on 2.5, with the exception of the desired_controller_period_ms variable in the command message; that's not present in 2.5.
You can also look at the code for the pub_atlas_command tool, which we use for testing.
That helped. Thanks
Luis Filipe Rossi gravatar imageLuis Filipe Rossi ( 2013-05-07 10:44:59 -0600 )edit
Asked: 2013-04-25 11:23:04 -0600
Seen: 103 times
Last updated: Apr 26 '13
