GUI Plugin linker error: undefined symbol
I tried to implement a GUI Plugin for Gazebo11 client. As a baseline I used tutorial (here).
Building went fine, however, I encountered some problems, when i tried to run the plugin with gzclient --verbose --gui-client-plugin libmygui_plugin.so.
Error was:
[Err] [Plugin.hh:178] Failed to load plugin libmygui_plugin.so: /home/user/catkin_ws/devel/lib/libmygui_plugin.so: undefined symbol: _ZTVN6gazebo15MyGUIPluginE
I believe it was a linker problem and has to do something with my code structure, which is:
 /plugin
 CMakeLists.txt
    /src
        MyGUIPlugin.cc
    /include
        MyGUIPlugin.hh
My CMakeLists.txt is:
cmake_minimum_required(VERSION 3.0.2 FATAL_ERROR)
project(gui_plugin)
if(POLICY CMP0100)
  cmake_policy(SET CMP0100 NEW)
endif()
set (CMAKE_AUTOMOC ON)
find_package (Qt5Widgets REQUIRED)
find_package (Qt5Core REQUIRED)
find_package(Protobuf REQUIRED)
find_package(gazebo REQUIRED)
include_directories(include SYSTEM ${GAZEBO_INCLUDE_DIRS}
        ${Qt5Core_INCLUDE_DIRS}
        ${PROJECT_SOURCE_DIR}/include
        ${PROJECT_SOURCE_DIR}/src
        ${catkin_INCLUDE_DIRS})
link_directories(include ${GAZEBO_LIBRARY_DIRS}
set (CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} ${GAZEBO_CXX_FLAGS}")
QT5_WRAP_CPP(headers_MOC include/GUICameraPlugin.hh) # This solved my problem <--------------
add_library(mygui_plugin SHARED ${headers_MOC}
        src/MyGUIPlugin.cc)
target_link_libraries(mygui_plugin ${GAZEBO_LIBRARIES}
    ${roscpp_LIBRARIES}
    ${Qt5Core_LIBRARIES}
    ${PROTOBUF_LIBRARIES})
There is a line marked, which solved my problem. I found this somewhere in Gazebo source code, but I don't know, how it works, why it helped and most importantly, is this the correct solution? Interesting also is, that if I remove Q_OBJECT from my header file class definition, the problem disappears.
I am not an expert on CMakeLists, so I most probably have many unnecessary things in my CMakeList. I would appreciate any comments about those, but I am very curious about the main problem. Also, if someone deals with similar problem, this might be helpful.
Thanks for any notes and ideas!
Asked by m.bahno on 2020-08-13 11:06:00 UTC
