Imported Gazebo model texture error!
I made a simple gazebo model using blender, then exported the .dae into the model folder. But when I tried it in gazebo, the surface textures appeared on the other side off the surface (inside surface). How can i solve this problem??
Asked by rayhan_haqi on 2020-08-15 01:12:29 UTC
This looks like you add to a wrong surface when you unwrapped the object to add the texture at blender. It has several examples of adding texture over surface at blender, try it and check on gazebo if works
Asked by dregner on 2020-08-19 13:38:27 UTC
Looks like your normals are flipped. You'll need to go back to blender and flip your normals. Here is some info on how to do this.
https://docs.blender.org/manual/en/latest/modeling/meshes/editing/mesh/normals.html
Asked by Cole on 2020-12-18 14:16:34 UTC
