Collision issue on gazebo 9 ?
Hi everyone,
I face some trouble to place a boat on a step to study its motor and steering.
image description
This occurs from both sides of this catamaran-like boat
image description
Seems that the hull is inside the step, is it an issue with the physic engine (default ODE) or the mesh ?
I launch gazebo through a roslaunch file and a test world.
Here is the part of the URDF file describing the hull :
<link name="boat_link">
        <mass value="38.718"/>
        <inertia ixx="16.283" ixy="0.008" ixz="0.458" iyy="19.728" iyz="0.0" izz="33.013"/>
    <collision>
            <mesh filename="package://aquanaute_description/models/meshes/Assambly_aquanaute.stl"/>
    <visual>
        <origin rpy="0 0 0" xyz="0 0 0"/>
        <material name="gray"/>
Asked by Tomlogan on 2020-08-18 08:35:09 UTC
hello, what is the value of the min_depth and max_vel parameter ? Explanation about those parameters are here, "constraints parameters" 3 & 4. Are you sure that for the step the visual and collision geometry are the same ?
Asked by Clément Rolinat on 2020-08-26 03:07:48 UTC
I didn't configure ODE parameters, it's the default one. I display the collision over the visual as orange overlay.
Asked by Tomlogan on 2020-09-04 06:12:00 UTC
