Gazebo 10.1 on Fedora via MobaXterm or PuTTY/Xming starts with black scene
Starting Gazebo via MobaXterm, which has a built in X11 forwarding, as well as PuTTY with Xming starts with a black scene. The menu options to work. The --verbose flag doesn't reveal any errors nor warnings.
What it should look like: C:\fakepath\unnamed.png
What it does look like: C:\fakepath\blackscreen.JPG
Also testing via X2Go, we have to change the LD_LIBRARY_PATH=/usr/lib64/libgl-xlib:${LD_LIBRARY_PATH}
following this suggestion and same issue but we do get these warnings:
[Wrn] [GuiIface.cc:122] X server does not support XInput 2
[Wrn] [GuiIface.cc:122] QXcbConnection: XCB error: 1 (BadRequest), sequence: 168, resource id: 78, major code: 130 (Unknown), minor code: 47
[Wrn] [Publisher.cc:142] Queue limit reached for topic /gazebo/default/physics/contacts, deleting message. This warning is printed only once.
AL lib: (WW) alcCloseDevice: Releasing context 0x55b4ea4214b0
AL lib: (WW) alcSetError: Error generated on device (nil), code 0xa002
Any fix for this?
Asked by RobbieTheK on 2020-08-20 15:27:30 UTC
A quick fix is to use the COPR repo and upgrade to 11.1
Asked by RobbieTheK on 2020-08-24 10:23:10 UTC
