Why do I get "core dumped" error while subscribing to a topic ?
Hi !
I try to create a library, which is directly linked to my simulated robot in Gazebo. Here, I want to access some data such as speed rotation rate of the wheels, their position and so on. I get those values in my World plugin and publish them on topic, using a custom message :
message WheelBoardStateMsg
required string name =1;
required float drive_speed_radps_ =2;
required float steering_speed_radps_ =3;
required float abs_angle_rad_ =4;
and :
message WheelBoardStateMsgMultiple
required WheelBoardStateMsg wheelboard_1_state =1;
required WheelBoardStateMsg wheelboard_2_state =2;
required WheelBoardStateMsg wheelboard_4_state =3;
required WheelBoardStateMsg wheelboard_8_state =4;
In my library, I want to be able to subscribe to this topic so I created this subscribing function :
typedef const boost::shared_ptr<plugin_msgs::msgs::WheelBoardStateMsgMultiple const> ConstWheelBoardStateMsgMultiplePtr;
// Function is called everytime a message is received.
void robot_gazebo::callbackwheelboard(ConstWheelBoardStateMsgMultiplePtr &_msg){
std::cout << "message received\n" << std::endl;
std::cout << _msg->DebugString() << std::endl;
int robot_gazebo::subscribeToWheelboardsState(){
// Listen to Gazebo topic
gazebo::transport::SubscriberPtr subwheelboardstate = this->robot_node->Subscribe("/gazebo/robot_world/robot/wheel_board_state_messages", &robot_gazebo::callbackwheelboard, this);
// Busy wait loop...replace with your own code as needed.
gazebo::common::Time::MSleep(10);
return 0;
I am trying to execute this test file :
int main(int _argc, char **_argv)
robot_gazebo *my_robot = new robot_gazebo(_argc, _argv);
while (1)
my_robot->subscribeToWheelboardsState();
return 0;
with :
robot_gazebo::robot_gazebo(int _argc, char **_argv)
// Load gazebo
gazebo::client::setup(_argc, _argv);
robot_gazebo::setRobotName("robot");
robot_gazebo::setTopicName("~/"+robot_gazebo::getRobotName()+"/joint_cmd");
robot_gazebo::createNode();
robot_gazebo::~robot_gazebo()
// Make sure to shut everything down.
gazebo::client::shutdown();
void robot_gazebo::createNode() { // Create our node for communication
gazebo::transport::NodePtr a_node(new gazebo::transport::Node());
a_node->Init();
robot_gazebo::setNode(a_node);
void robot_gazebo::setNode(gazebo::transport::NodePtr newnode) { this->robot_node = newnode;}
When I execute this script using
gdb ./test core
it is working for a while and then I get this error :
test: /usr/include/boost/smart_ptr/shared_ptr.hpp:734: typename boost::detail::sp_member_access<T>::type boost::shared_ptr<T>::operator->() const [with T = gazebo::transport::Connection; typename boost::detail::sp_member_access<T>::type = gazebo::transport::Connection*]: Assertion `px != 0' failed.
Abandon (core dumped)
Thread 4 "test" received signal SIGABRT, Aborted.
[Switching to Thread 0x7fffc4dc7700 (LWP 16019)]
__GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:51
51 ../sysdeps/unix/sysv/linux/raise.c: No files or folders of this type.
Does anyone know what is going on? Thanks in advance, have a good day.
Asked by laura on 2020-08-31 04:37:35 UTC
